Page 107 of 135 FirstFirst ... 75797102103104105106107108109110111112117 ... LastLast
Results 1,591 to 1,605 of 2011
  1. #1591
    newone's Avatar
    Oct 2016
    Hello,in seat ibiza 2001 remote i think is 1M0959753C,can i use instead 1J0959753CT and what is the learning procrdure?
  2. #1592
    Oct 2015
    Quote Originally Posted by newone View Post
    If this is 433 MHz generate 1j0959753n. Coding if i remember good thru comfort module (46)
  3. The Following User Says Thank You to klesk1986 For This Useful Post:
    newone (27th May, 2018)
  4. #1593
    newone's Avatar
    Oct 2016
    Quote Originally Posted by klesk1986 View Post
    car has one remote allready but not work properly,i had tried to program a new with skp900 and fvdi but both of them could not do,fvdi say not available for this car?
  5. #1594
    Dec 2010
    Nottingham
    use the manual procedure for the remote
  6. #1595
    newone's Avatar
    Oct 2016
    Quote Originally Posted by rapidlocksmiths View Post
    Hello Martin,what is the corect manual procedure for this,i searched the net and find several,failed with all,thanks in advance for any info
  7. #1596
    Dec 2010
    Nottingham
    programmed key in the ignition and switch ignition on
    lock door with 2nd key manually
    press unlock button once
    wait 5 seconds then press unlock button once again
    now open door manually , switch ignition off and remove key and test the remote functions.
    if programming 2 remotes , when you do second one follow same procedure but press unlock twice each time instead of once
    also make sure you are using the correct remote , on that year it may be 1J0 959753N but could also be 1J0 959753 DA or AH , and can also be 1J0 959753 CT or AG
  8. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  9. #1597
    Dec 2015
    Rafah, Palestine
    those in the old zone works good if edit data?
    what data i need to edit plz
  10. #1598
    newone's Avatar
    Oct 2016
    Quote Originally Posted by just4upal View Post
    remote config data
  11. #1599
    Rito's Avatar
    Somenoe know about garage remotes?
    I see this new types for garage only..
  12. #1600
    Sofia, Bulgaria
    Hello, my question is about Xsara Picasso 2004y. Anybody did successfully key for the car? Original is two buttons ASK.
  13. #1601
    Sep 2016
    Hello.Ford focus 2013-14.
    Which image to use?
  14. #1602
    Mar 2017
    2012-15 New Focus Ranger
  15. The Following User Says Thank You to Daveskeys For This Useful Post:
    lock66 (1st June, 2018)
  16. #1603
    Sep 2016
    Nissan Micra 2018
    Original remote key PCF 7961
    Can do KD900 Image remote key???
  17. #1604
    Dec 2010
    Nottingham
    no not on kd
  18. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  19. #1605
    newone's Avatar
    Oct 2016
    Hello,today tried 107 and aygo,have done those before and was ok,today no luck,both cars go in programming mode(locks lock-unlock)but did not accept new remote,any idea?
