do not know what to say,with v3 i did one last week and worked perfect
Ok thanks.
Im now going to leave this job.
Thanks for the reply
the car is going on programming mode lock unlock?
The locks cycle.
I press button on original & locks cycle i then press button on key diy but nothing.
If i do the same but key diy first then nothing so i press button on original and locks cycle no problem.
something you do wrong,after lock-ulock confirmation for entering programming mode if correct remote locks cycle once,if wrong cycle twice,you say keydiy makes nothing,this does not make sence
I am doing the same thing each time BUT i use original remote first then key diy.
Next time i do the same thing buy key diy first then original.
No matter which way i try only original works.
I have now left the job
OPEL DELPHI S-AM
Tried 2 on different occasions with different remotes, on alarmed Astra and Zafira both 2003, no joy
Original S-AM works OK.
Anyone had any recent luck with this one.
Don't know if this ever worked, or is another one that stopped working after one of the updates.
keyprogramming (24th June, 2018)
Any idea what remote for Honda civic 2006 eu?
Has to be separated transponder
Inviato dal mio HTC 10 evo utilizzando Tapatalk
Mazda MX-5 2011 EU model. Genuine remote has 4 buttons, part number SKE126-01.
So with KeyDIY using a 3 button remote, and software SKE126-01-2009DJ4585, I get lock and unlock buttons working fine. However, the third button which would be really useful if it was the boot, doesnt seem to do anything. Is there any software which works correctly, or any other suggestion to get the boot button working ?
Thanks,
use the keydiy 4 button remote
Just looked on the 3D website, there only seems to be 3 button ones.
Just looked on Tradelocks website, there are 4 button keydiy remotes, but the 4th button is panic. Is that what you meant or did you have something else in mind ?
i use the 4 button from tradelocks all the time on these without issue , you need to make the SKE126-01-2009 from software .
also worth checking boot is properly locked down on its catch .
madaxe (30th June, 2018)
Nb multi key reusable? Could be overwriten?
