Page 114 of 135 FirstFirst ... 1464104109110111112113114115116117118119124 ... LastLast
Results 1,696 to 1,710 of 2011
  1. #1696
    auto techniek's Avatar
    Mar 2017
    I ve a issue programming remote to vw Polo 2010. Tried almost all option without suc6. Tried vvdi2 and skp.
    Any help is welcome.
  2. #1697
    Feb 2014
    That should be easy - what is the original remote part number?
  3. #1698
    Mar 2017
    I don t know.
    Car comes with no remotes. Only mechanical key
    Any idea which part nr for this car. I ve tried almost all.
  4. #1699
    foxtec800's Avatar
    Check with the dealer as not all polos have remote locking function
  5. The Following User Says Thank You to foxtec800 For This Useful Post:
    auto techniek (23rd August, 2018)
  6. #1700
    Feb 2014
    And you are sure it has RF module?
    By the way which mask is the Polo 9N3 or 6R?
    If it's 6R maybe you should try 1K0 959 753 N or 5K0 837 202 Q .
  7. The Following User Says Thank You to autoTkey For This Useful Post:
  8. #1701
    Mar 2017
    It is 6R from 2010
    I wil try and repport
  9. #1702
    Oct 2015
    Like autotkey wrote check type of central electric - is it low, medium or high. Not all types support remotes. Proper remote for 6R is with end N or 5k0
  10. The Following User Says Thank You to klesk1986 For This Useful Post:
  11. #1703
    Sep 2016
    Hello.
    Chevrolet Malibu 2008 Orig.key B-111PT
    What key blank need for KD900.
  12. #1704
    Oct 2011
    Quote Originally Posted by auto techniek View Post
    It is 6R from 2010
    6R we always use the kd with AD at end , we use 433 but you might be 315 Mhz
  13. The Following User Says Thank You to raptureready For This Useful Post:
    auto techniek (27th August, 2018)
  14. #1705
    Feb 2014
    Kia sportage remote 2007 Europe
    Can one point me in the direction of the above remote. I feel like iv tried them all but no joy. It's the separate fob
    Cheers
  15. #1706
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Anyone tried touareg id46 old zone 433 generate on multi?
  16. #1707
    Sep 2016
    2 BUTTON CIVIC JAZZ CRV HRV HL1K-3T pcf 7936 Orig.
    Is it possible to generate remote key for KD900?
    honda civic 2012 hatchback ---KD900 with 2013 NEW CRV ACCORD FIT,433MHZ-OK
  17. #1708
    Sep 2016
    Hello.
    Nissan Qashqai 2013 .Original remote 2 button/pcf 7936.
    Which one to use create key for KD900.
  18. #1709
    Sep 2016
    Default Kia Picanto
    Kia Picanto 2016.
  19. #1710
    Feb 2014
    lock66 next time try searching the database - https://keyfast.knack.com/kd900
    If it's not in there you can test it and add it.
  20. The Following User Says Thank You to autoTkey For This Useful Post:
    Pezhoo (7th May, 2023)
