Page 85 of 135 FirstFirst ... 3575808182838485868788899095 ... LastLast
Results 1,261 to 1,275 of 2011
  1. #1261
    newone's Avatar
    Oct 2016
    hello,i try on peugeot 206 2002 with nb as prompt,programming key is ok but when i try to program remote no success,any ideas?
  2. #1262
    coolsoda's Avatar
    Apr 2008
    Scotland
    New update Has Mini/Rover 75 Key ,but without Barcode a bit of a waste of time,also developing use in there stupid android system,and not compatible with kd900 unless you connect it with an android device.
  3. #1263
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by coolsoda View Post
    There is barcode, after generating remote on phone screen will show you barcode, but didnt try it.
  4. The Following User Says Thank You to mikajna For This Useful Post:
    doctore (24th April, 2017)
  5. #1264
    coolsoda's Avatar
    Apr 2008
    Scotland
    Quote Originally Posted by mikajna View Post
    No i did not try it because its not compatible with my PC KD900 setup
    "THIS REMOTE NEED PIN code
    now only support ANDROID system to add.
    in other words you need use KD900+ with android phone.
    for KD900 users you need use OTG cable Connect your device to Android phone. in MOBILE KD forum you will see how to do"
  6. The Following User Says Thank You to coolsoda For This Useful Post:
    mikajna (21st April, 2017)
  7. #1265
    May 2017
    birmingham uk
    can anyone tell me what to ues for a uk 2007 vw fox remot ?
  8. #1266
    Apr 2016
    uk
    I think is the same as polo
    1K0959753N
    1J0959753B
    Inviato dal mio HTC One utilizzando Tapatalk
  9. #1267
    May 2017
    birmingham uk
    thanks i will give them a try ,
    these should program in manually ,
  10. #1268
    auto techniek's Avatar
    Mar 2017
    is URG200 the new version of KD900?
  11. #1269
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by auto techniek View Post
    URG200 mostly for chinese market.
    If I helped you know what to do..
  12. The Following 2 Users Say Thank You to AndyCZ For This Useful Post:
    auto techniek (4th May, 2017), mikajna (7th May, 2017)
  13. #1270
    Feb 2014
    Quote Originally Posted by AndyCZ View Post
    Not true! URG200 replaces KD900. Has the same functions and uses the same remotes(series B and NB).
  14. The Following User Says Thank You to autoTkey For This Useful Post:
  15. #1271
    M3L3R's Avatar
    Mar 2014
    Kolobrzeg
    Remote controle working on renault kangoo 2006 (sagem 93c66) but immo doesnt work. I add pcf7936, remove coil from remote circuit board and after that all was fine. Everything prepared by Tango. KEYDIY REMOTE FLIP (NB10-ATT-46) ID46
  16. The Following 2 Users Say Thank You to M3L3R For This Useful Post:
    AndyCZ (10th May, 2017), triak88 (8th May, 2017)
  17. #1272
    Quote Originally Posted by M3L3R View Post
    Now just wait until the remote becomes out of sync....
  18. #1273
    M3L3R's Avatar
    Mar 2014
    Kolobrzeg
    WoW... any solution on that? Only original remote?
  19. #1274
    coolsoda's Avatar
    Apr 2008
    Scotland
  20. #1275
    CaioW's Avatar
    Oct 2015
    Everywhere
    Hi guys,
    All the new updates into the APP is released on the KD900 on pc?
