i am buying a used kd900 does it need tokens or are they tokens free thank you .
Hi guys, did someone already used the Fiat remote available in kd software ?
kronk92 (6th November, 2017)
ok thank you, i saw that they updated a lot of times
Can Anyone confirm Key-diy for Jeep grand cherokee 433 mhz. Is it working or not?
car is 2007 model 3 btn no panic btn
Honda Accord 2006. Tried HD32.4 433Mhz in software onto B11 remote. LED not working after programming with KD900.
Tried another remote. This has definitely has working LED before programming with KD900, after, LED not work.
Tried another remote. This after programming with KD900 LOCK and UNLOCK button makes LED fine. Boot button LED is very faint. Program to car all works but after few boot presses then boot button stops working.
Either lots of broken remotes or software is broken or something else ?
I had similar problem with audi style key. The reason was poor soldering chip on board. First check microswitches with multimeter, if needed replace, than resolder board. This remotes are very cheap so we can't expect perfect quality.
Hi , thanks for reply. buttons work prefectly before prog with HD32.4 sofware. Work perfectly with Other software. Only problems with HD32.4.
2009 Toyota Auris 433 UK spec.
Has anyone had any luck with one of these.
Remote insert marking 89071-02030.
Thx
keyprogramming (14th November, 2017)
Lexus RX400h 2008 433 UK Spec 3 button
Insert marking 48060 12H04
Anyone had any luck creating one of these
Thx
