Page 94 of 135 FirstFirst ... 44848990919293949596979899104 ... LastLast
Results 1,396 to 1,410 of 2011
  1. #1396
    kronk92's Avatar
    Sep 2016
    France, paris
    peugeot 307 van 2004 fail ! tried old flat A & B also the remote for 307 with nb multifunction none of them work
  2. #1397
    Feb 2014
    Just spent an hour trying the same thing. KeyDIY still no good for the K-line PSA cars...
    It was a Peugeot 307, year 2001.
    I tried:
    - 307 OLD FLAT A NB Multifunction (car didn't accept it)
    - 307 OLD FLAT B NB Mulitifunction
    - PSA CIR40
    - PSA CIR41
    - PSA CIR43
    - PSA CIR44
    - PSA CIR46
    - PSA CIR51 Peugeot 406 2001-2004
    - PSA CIR53 (car didn't accept it)
    - PSA CIR57 Peugeot 307 2001-28.03.2005
    All were accepted by the car except where noted else. Meaning they start the engine, but don't lock/unlock the doors.
  3. The Following 2 Users Say Thank You to autoTkey For This Useful Post:
    kronk92 (18th November, 2017), lalaina74 (18th November, 2017)
  4. #1398
    Oct 2017
    Quote Originally Posted by foxtec800 View Post
    Can Anyone confirm Key-diy for Jeep grand cherokee 433 mhz. Is it working or not?
    car is 2007 model 3 btn no panic btn
    Yes Chrysler OHT 433 works. I have done in old nb zone and on multi function.
  5. #1399
    keyprogramming's Avatar
    Kia Picanto 2011-2014 95430-1Y300 (3rd party)
    Tried in 2012 UK registered Picanto.
    No joy, original reprograms OK.
  6. The Following User Says Thank You to keyprogramming For This Useful Post:
    kronk92 (21st November, 2017)
  7. #1400
    Hyundai 95430-D3100
    Tried in 2017 UK registered Hyundai Tuscon
    No joy, original and new OEM programs OK.
  8. The Following 2 Users Say Thank You to keyprogramming For This Useful Post:
    fytfh (22nd November, 2017), kronk92 (21st November, 2017)
  9. #1401
    newone's Avatar
    Oct 2016
    Toyota iq 2010 under tokai riki b41ta ok
  10. The Following 4 Users Say Thank You to newone For This Useful Post:
    doolittle (24th November, 2017), Faraday (24th November, 2017), kleidaras (23rd November, 2017), kronk92 (23rd November, 2017)
  11. #1402
    Oct 2016
    Scotland
    Quote Originally Posted by coolsoda View Post
    The Barcodes for the Mini & Land Rover are all starting with the Prefix N and checksum is + so i assume it was never tested.
    anyway of converting the barcodes back to 6 digit serial number
    Just seen your post, not sure if anyone had replied (not read through the entire thread yet)
    The 6 digit serial is the first 6 characters after the N in barcode 1.For example if barcode 1 is *G380D1C380D1BFFX* then the text in red is the serial number.
    I come across your post when actually looking for some info myself maybe you know the answer.
    The standard Valeo fob are programmed in to operate the central locking and immobiliser using the barcode or serial number. My question is if i generate a new remote using KeyDIY (they recommend a B-series remote), then how can i generate this transponder to code into the car same as remote (i.e. put in one serial or barcode)?
  12. #1403
    Mar 2014
    West Sussex UK
    Quote Originally Posted by WRX 14 View Post
    For LandRover there is no transponder just remote. For Rover 75 or BMW Mini it’s EWS3.
  13. The Following User Says Thank You to Cromwe11 For This Useful Post:
    WRX 14 (25th November, 2017)
  14. #1404
    Oct 2016
    Scotland
    Thanks, so if i prepare a Land rover 433 remote into B series remote, and code the serial number into the BCU, both the central locking will work and it will start? I was thinking the transponder may be integrated into the fob PCB. Transpondery.com shows that Disco II has ID46 transponder.
  15. #1405
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    no transponder. the remote system is the immobiliser
    I am a FUD
  16. The Following User Says Thank You to obdsystems For This Useful Post:
    WRX 14 (27th November, 2017)
  17. #1406
    Anyone had any luck creating a 2 button remote for a UK Spec 2012 Kia Picanto
    Tried 95430-1Y300 but doesn't work
  18. #1407
    newone's Avatar
    Oct 2016
    Quote Originally Posted by keyprogramming View Post
    try this one
    Morning 95431-07901
  19. The Following User Says Thank You to newone For This Useful Post:
    keyprogramming (2nd December, 2017)
  20. #1408
    AndyCZ's Avatar
    Jan 2014
    EU
    Hyundai i20 2009 tried all remotes - no luck.
    If I helped you know what to do..
  21. #1409
    Oct 2013
    thank you pinky your a star martin ,just KD 900 awesome kit i have supply 20 remotes with no problems i had to drill a hole to take a tpx 1 chip for ford but worked fine KD900 will not do Land Rover Freelander 1 Remotes and early Rover I found ,I drive Freeland 1 and cant progam remote for my car
  22. #1410
    Quote Originally Posted by newone View Post
    try this one
    Morning 95431-07901
    I'm going back next week to try again, will update afterwards
