newone (2nd June, 2018)
dThnks Martin,i really can not understant what was gone wrong,both cars went on programming mode and after when hit buttons recycle 2 times,incorect remote,tried with 106-107-c1 and aygo configarations in both cars but nothing...
you tested remote , giving a good signal ? as not expensive i tend to use oem remotes on C1 and 107 , but i also have an old kd200 that i use on an old pc with old software when issues arise on updates .
i know,it is more easy with oem remotes but i like more kd design,remote was ok with fresh good quality battery,i have an old version too,i will try with that again,in my main pc i update every time so i will see if it is problem with new update,again thanks for your time to answer.
Hello.Honda Civic Remote key PCF 7961.
Which image to use?
2010. Civic Hybrid.
Today tried to make remote for A1 Audi. Key programmed but remote no way. This one 8X0837220
May be need integrated remote and chip in one pcb. But can t find one.
Any ideas?
hi,
yes must use integrated key , and remote will work diretly . for programming it use Avdi.
https://auto-keys.eu/index.php?route...oduct_id=44096
you can ask for no keyless model.
auto techniek (8th June, 2018)
comizelu (10th June, 2018)
After update KD900 to new version. under special copy Managed to copy TX-111 remote to B09 and it works.
regards, finnie from down under
Peugeot 107 doesn't work - locks just cycle twice, didn't these work previously?
toyota verso akıllı sistem kd900 civarında resim ekle
kd remote works in this cabinet
information sharing
lalaina74 (19th June, 2018)
