8Z0 837 231 D original you can use newer type 8P0 837 220 D
I had a Audi A4 2003 and I programmed a 8P0 837 220 D to it, I haven't tried keydiy type on one yet but original worked.
I have said this before, don't think anyone listens tho
doolittle (7th November, 2014)
Im doing 1 next week will report
8Z0 837 231 D none of the KD900 current models match. I have tested them all.
New update out for KD900 Remote Generator, loads more coming KD900 can be used as stand alone unit or Linked to your Laptop
Smart Match ,Frequency Tester all good to have ,Simulate Remote , Simulate Device Both save you time and Money and tokens you can test the Remote before you Generate it, All so very Good, as Rapidlocksmith said More Remotes Being added all the time 260+ i up date the Tool once a week, well worth the investment if it does all it say's it can do
DottoreBL (6th February, 2015)
7E0 837 202 M would be nice, for the facelift VW transporter, bloody expensive.
I see the application list is included in the "KD900 operation manual.pdf"
I downloaded the software as well, and tried to run it. But my antivirus program did not like it on Win 7 PC. Stopped it from working after 30 seconds. But I could open it several times to have a peak.
Need to have some adjustments on the antivirus program to make it go smooth.
I have a an old KD900 manual from December 2013 as well, with application list. I can see they have made huge updates since then on the software.
But now also easy to search by brand, model and year from PDF KD900 Manual. Good info to have anyway. Worth sawing for later.
I guess this is a must have product.
But not updated yet with:
VW Transporter 2010- 7E0837202M
VW Transporter 2010- 7E0959753M
can someone give me web adress where to buy KD900 ?
Thank u
1. work with the pc software
update to the latest software , you can see smart march button on the soft and press the remotes on the kd900 surface
and press any button , it will pop out the wanted remotes automaticalllly
2. work without the pc software
go to smart march item on kd900 machine and also press any button to tell which one to choose.
buuuuuuuuuuuuuuuut
this function is not accurate, but it does work well for ford and vw .
and this function only for kd900, not for kd200 or other machines
So in a lost key situation it will tell me what remote to use on the vehicle?
Is there a way to find out exactly what remote part number the car left the factory with?
