Just noticed that Tradelocks have some new ID46 remotes, one looks like a Honda flip (NB10) and the other the latest style PSA flip (NB11)
http://www.tradelocks.co.uk/keydiy-r...p-remotes.html
I'll order a few before they run out
mikajna (22nd January, 2016)
today make key for peugeot 206, 2004 year
car start well but remote doesn t work
someon try make this key model ?
PUSH reputation and thanks If you think I helped .............................
No luck, all the below failed
From the start of the KD900 menu
307 0536 ASK
408 0536 FSK
0523 ASK
508 C4L 3008
0523 FSK
0523-ASK
0523-FSK-3
Pity that I could not find one that would work, as I get loads of enquiries for C4's, just have to carry on using the real ones.
Jimmy, any chance of looking at this one as there is a good demand for it throughout Europe
whiskeyman (22nd January, 2016)
Same as for me, firstly I try with NB07 v2.0, after that I got NB07-1 v3.0 and also neither remote does not work from menu for peugeot 308 2009...I was try every flip remote with 2 and 3 buttons, even is original remote with 2 buttons.
Dont know what is problem, but car started with almost every try, but remote never managed to work.
are you guys who are trying different PSA remotes using the same remote then uploading the different firmware then reprogramming to the car?
If so jimmy already said if a remote does not work then do not reuse the remote on that car.
I believe he means that because the key ID is already in the car that the new remote config will not be entered into the system and it will keep the old config.
Maybe you could reuse the same remote on the car if you first program just the old key to remove the KD key from memory, then try reprogramming the KD key with the different firmware??
Fallen (23rd January, 2016)
Honestly I didnt check that this time after programming, but when I was programming on peugeot 307 than I check ID and was changed, didnt check this time with 308, maybe now didnt change, but will check and that soon as I can.
Maybe that is problem if dont change ID, how we can solve that, did we must erase all keys, program only original key, than program NB remote...will that be ok?
First impressions of the new NB11 (PSA) is that it feels solid.
The cover comes off easily without the worry of snapping off bits.
Takes the normal 14mm badge, but badge space is flat at the bottom, not convex, so no support in the middle of the badge if it takes a hit
Takes most blades but you'll have to file about 1mm off the tips to fit the big ones like HU58 and HON66.PSA New-1.jpgPSA New-2.jpgPSA New-3.jpg
Some of the wide shouldered blades like MAZ24R and HU133 need the side shoulders filing down about 0.5mm
I'm guessing that this may work, if not then the only way to do it would be to have a remote for each firmware version, then program each until you find the one that works - then simply replace that key with another so you still have a set of all the firmwares.
You can also check this very easy.
Do the above until you find the correct remote. Then with one of the keys that didn't work program this with the correct firmware and then try to program it - if it works you know you can reuse if you make sure its removed properly before reprogramming.
You can also intentionally program a wrong firmware version, then do not delete it from the car and program the correct firmware and try to program it to the car and seeing it it works, if not then delete from memory and try to program again and see if it works.
mikajna (24th January, 2016)
For what its worth, back in September posting #500 I tried a few until I found the right one for a 2009 Peugeot 207CC.
I used the same remote changing the firmware each time, but used the original flip remote as the first key each time.
I programmed it with an AD100Pro which erases any existing keys, but don't know how this differs from other programmers.
paul_12345 (25th January, 2016)
