Page 52 of 135 FirstFirst ... 242474849505152535455565762102 ... LastLast
Results 766 to 780 of 2011
  1. #766
    autochei's Avatar
    Mar 2013
    romania
    it s some remote like touareg someone say here can do it
    but i ask u why use kd when in china it s 18 $ ori key?
  2. #767
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by autochei View Post
    That is not ori key mate, that is also china remote ori is far a way, but Im guarantee that is Keydiy remote better than other remotes made by china, second thing its not just for Touareg but is universal for other 7946 like renault, audi, fiat...and it cant be locked.
  3. #768
    autochei's Avatar
    Mar 2013
    romania
    if u say................................
  4. #769
    cantabria, north spain
    Hello, are you planning to develop remote for Audi a4 2003 8z0837231d? Or is there a variant that can be used ?
    Tried all of them no success
  5. #770
    Atex31's Avatar
    Feb 2011
    UK
  6. #771
    Dec 2013
    aodi A4 CAN NOT BE GENERATED BY KD
    ITS HARDWARE VERY ACCUATE.
    WE HAVE IT FULL ALGO
    BUT KD HARDWAER CAN NOT MAKE IT FOR AUDI A4
  7. The Following 2 Users Say Thank You to jimmykey For This Useful Post:
    Atex31 (12th February, 2016), tomasete (10th February, 2016)
  8. #772
    cjawahir's Avatar
    T&T
    Quote Originally Posted by paul_12345 View Post
    This has happened quite a few times for me, where it updates most then fails leaving it saying there is 1 that needs updating.
    yes same problem .
    cj
  9. The Following User Says Thank You to cjawahir For This Useful Post:
  10. #773
    keyprogramming's Avatar
    Quote Originally Posted by cjawahir View Post
    yes same problem .
    cj
    This problem only appears to be affecting the KD900, as my KD200 updates OK.
    Indicates that 43 updates are required, gets to 97%, waits for a few seconds, indicates SUCCESS, but 43 updates still needed.
    Maybe it will get sorted after the holidays are over.
  11. The Following User Says Thank You to keyprogramming For This Useful Post:
  12. #774
    Aug 2014
    Does anyone know whether the KD900 can do a remote for the Focus 2006? It's just the old tibbe horseshoe type. There is a Mondeo fob listed in the app, but don't know whether this'll do the Focus - I wish the images on the apps list were a bit more meaningful!
    Don't know how to search this thread, so apologies if this question is in here already!
  13. #775
    Quote Originally Posted by cumbriaauto View Post
    Try this
  14. #776
    2010 Peugeot Partner 3B flip remote, original sticker JCAE ED15 633345.
    Successfully programmed using 408 0536 FSK.
    All 3 buttons inc middle one for back and side doors only all working OK
    Big saving on original price of around ?65.00
    Thought I had an intermittent remote problem, RCL worked, then didn't.
    Realised that if you press the buttons quickly it doesn't always work, but if you keep pressed for at least 1 second, works every time
  15. The Following 3 Users Say Thank You to keyprogramming For This Useful Post:
    just4upal (14th February, 2016), Recoder (30th April, 2016), truedetective (13th January, 2017)
  16. #777
    Aug 2014
    Quote Originally Posted by keyprogramming View Post
    Thanks, yeah I saw that, just wondering if anyone knows whether it will work for focus. I was going to try this and take a genuine along in case the kd fob fails, but if the chip goes in, and the kd remote fails, it means a wasted token or having to swap the chip in the original. Need to know it'll work before programming the kd chip.
    Sent from my Harrier from EE using Tapatalk
  17. #778
    Ford remotes are pretty much the same and not model specific, programming is mostly manual.
    Cycle a key between ignition on and one click back 4 times and you should hear a chime.
    Press any button on all remotes present and you should get a confirmation chime with each one that is accepted
  18. The Following User Says Thank You to keyprogramming For This Useful Post:
    cumbriaauto (14th February, 2016)
  19. #779
    Feb 2014
    Does anyone know are the citreon berlingo remotes and partner remotes interchangeable?
  20. #780
    Dec 2013
    Quote Originally Posted by doolittle View Post
    kd900 can renew NB SERIES KD REMOTES
    IT ALSO WORK FOR ALL PSA
