Page 53 of 135 FirstFirst ... 343484950515253545556575863103 ... LastLast
Results 781 to 795 of 2011
  1. #781
    Fallen's Avatar
    I have seen a long and a short HU92 blade.
    The longer version works for Range Rover Vogue but I can't track them down any more.
    Anybody got a link for them?
  2. #782
    keyprogramming's Avatar
    Quote Originally Posted by keyprogramming View Post
    This problem only appears to be affecting the KD900, as my KD200 updates OK.
    Indicates that 43 updates are required, gets to 97%, waits for a few seconds, indicates SUCCESS, but 43 updates still needed.
    Maybe it will get sorted after the holidays are over.
    Tried again this morning on the KD900, still the same but now indicates 42 updates.
    Can someone try updating theirs to see if they get the same.
  3. #783
    Sep 2010
    HI,
    Yes I have the same 42 updates.
  4. The Following User Says Thank You to triak88 For This Useful Post:
    keyprogramming (19th February, 2016)
  5. #784
    Quote Originally Posted by triak88 View Post
    HI,
    Thanks for confirming.
    Jimmy, can you look into this problem.
  6. #785
    Dec 2013
    next week will resoonve
    this 42 can not update to device
    they must work online
    so it is the mistake reportt by soft
    thanks for response
    those days updated many toyota for 2015 new cars
    pls share
  7. The Following 2 Users Say Thank You to jimmykey For This Useful Post:
    cjawahir (21st February, 2016), keyprogramming (20th February, 2016)
  8. #786
    Atex31's Avatar
    Feb 2011
    UK
    Mine updated on Thursday and none left over needing updates.
  9. #787
    Quote Originally Posted by Atex31 View Post
    Is that your KD200 or KD900?
  10. #788
    It doesn't matter what machine, now is update without machine connected
  11. #789
    Atex31's Avatar
    Feb 2011
    UK
    Both the KD900 and KD200 are all clear now.
  12. #790
    Jun 2013
    Quote Originally Posted by Weasel3 View Post
    KD team.
    Any chance to make a transition table from KD blades to the more famous ones. PDF, App or lookup database. Search both ways. vice/versa.
    Jimmykey:
    i understand it .
    it is really very important.
    _________________________________________
    Any progress on this request?
    Maybe just a PDF at the moment.
  13. #791
    Atex31's Avatar
    Feb 2011
    UK
    It still needs an option on the interface to click and show a choice of 433Mhz or 315Mhz.
  14. #792
    Jun 2011
    devon uk
    is it possible to make a key for nissan navara / micra k12?
    i can see 2 keys on laptop software but they seem to be a non transponder ones. the one i need is 7946 id46
  15. #793
    coolsoda's Avatar
    Apr 2008
    Scotland
    It does have you need to check/change the pages in hitag to make sure they are correct and use the ATT-46 key
    If you dont have this machine you can replace the PCF7946 on a used remote and fill in hitag pages with Zedbull
  16. The Following User Says Thank You to coolsoda For This Useful Post:
    robert81 (3rd March, 2016)
  17. #794
    Jun 2011
    devon uk
    havent seen this option in my kd. i need to update it.
    another question - nb11 remote i have problems generating them . kd900 says nxp commu error (tested on few fobs not only 1)
    ive been generating them ob but have problem since early this week. anyone with similar problem and solution?
    also which position should i choose to generate key for 2005 peugeot 407.
  18. #795
    gokey's Avatar
    someone generate successfully remote to peugeot 107 ?
    PUSH reputation and thanks If you think I helped .............................
