8z it s for audi a4 rb4 rb8 not worked
i have succes with citroen c1=toyota aygo and pug 107
: Ensure Ignition switch in OFF position and driver?s door open.
NOTE : This procedure must be completed within two minutes.
1. Switch the ignition ON and OFF.
2. CLOSE and OPEN the driver?s door TWICE ? so door ends up in the OPEN position.
3. Switch the ignition ON and OFF.
4. CLOSE and OPEN the driver?s door TWICE ? so door ends up in the OPEN position.
5. CLOSE the driver?s door.
6. LOCK the door using the door lock button on the door.
7. Switch the ignition ON and then OFF.
8. UNLOCK using the door lock button on the door - the locks will cycle to indicate programming mode.
9. Remove key from ignition.
NOTE : Some models require you to leave it in the ignition.
10. PRESS and release both LOCK and UNLOCK buttons on the remote transmitter.
11. PRESS and release LOCK button on the remote.
12. Check remote transmitters for operation.
[QUOTE=didi_du_93000;2947017]It's very difficult to know what software must use on psa remote!!!
I have lose 1hour with Citro?n C3 2004 without success.
So loosing 1 blade, 1 cut and 1hour of my time.
FOR CITROEN C3 TRY (307 OLD B) in the bsi> telecode> CUSTOMER OPTION> CENTRALIZATION> VARIANT TELECOMANDE (0A5A) work fine try this !!
AndyCZ (9th March, 2017), didi_du_93000 (1st March, 2017), Faraday (2nd March, 2017), kronk92 (2nd March, 2017)
Will try friday
with Tapatalk
(psa before 2006 0523 ASK 434MHZ) after last update not work.
Before it works well Of 2 last month I make 20 key. I try today does not work with citroen C4 2006 ask remote not work; i try with Peugeot 307 2005 ASK 434 not work!!!
I try all the model ASK REMOTE PSA on list not work. You can return please ( PSA ASK 433 MHZ BEFORE 2006) ????
did a 05 pug 206 car started remote not work
Has anyone had any success with NB11 - ETTGM on an Opel Insignia or AstraJ?
I tried today on Insignia and ZF said "transponder error"
But on reading the key everything seemed to be the same as the Original Key.
autochei (9th March, 2017)
Thanks for the reply. I'll try again on the next one. Where you using Zedfull?
what remote did you use?
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
mikajna (13th March, 2017)
peugeot partner 2015, generate 408 0536 fsk everythink work.
Has anyone recently generated a Sharan/Alhambra 2Button 7M3 959 753
Connects to 3rd party OK
Gets to between 25% and 75% of generating the board and bombs out.
Tried different cables, different boards B1, B2, B3 and even a B9, rebooting KD900 and laptop.
I'm sure I generated one these a few months ago without any issue.
