Try here ..
https://www.transpondery.com/vw-remo...s-catalog.html
Inviato dal mio HTC One utilizzando Tapatalk
Try here ..
Chevrolet Tahoe 3 button remote.
1996
P/N: 15731442
DOC/MDC: 218 K1035
Model/FCC ID: AB00104T
I have a non working remote.
Not normal buttons on these. Some kind of rubber pad, which is conductive. When pushing down, the button to the PCB.
Any tip to get it working again? Replaced with new batteries. But not able to get any signal when testing the frequency.
Edit: The fault is found. Battery metal clip broken. In one of two battery areas. Will not give power to PCB.
I see that this is not in KD or the Key Tool, so I can not generate a new one.
The question is:
If I had a working remote. Would I be able just to copy the remote with KD or other similar tool instead.
Would it work straight away, or do I need further programming into vehicle?
Thank you for any answers or tip.
Nothing works for Kia Ceed 2011 (first generation).
Need a remote for mondeo 2012 non proximity..the key listed 2012-2015 it will work?anyone tested ? Car have a non remote key and need a remote one..
Thank you
I have used successfully on Focus 2013.
comizelu (11th January, 2018)
4 or 8 times.
Just tryed to make Honda G8D-451H-A for Honda CR-V. Boot release button not worked at all (no signal when pressed) Lock/unlock works OK. I try to use few different B series remotes - same problem.
Original remote has trunk (rear window) button and it works. It small round one. Customer have original remote and was asking for spare one.
KIA RIO NEW 3 BUTTON 433Mhz
Anyone had any luck with one of these for the UK market.
Many thanks
Need make a remote VW Polo 5K0837202D from 2013. Is keydiy 5K0837202AD compatible?
auto techniek (16th January, 2018)
