I get several Peugeot /citroen flip keys,i am having a lot of trouble matching up to any of the numers in KD software,the most common ones are marked E28C101B,is this the number I should be looking at,there is also a label in them with 55228692.Would anyone know if any of the flip keys in the Peugeot citroen section would match these.I have several keys in stock and none of them seem to match the ones listed on KD software.Am I doing something wrong here.
pleaseny advce would be great,hopefully I will be able to use this KD900 soon,is it realy only suitable for a few of tolder cars with separate transponder chips ?
mitsubishi colt 2007 7941 programmed with mf benz ok
Hyundai i20 2011..???
Oka-185t is not on the list .
Did someone tried something else?
Inviato dal mio HTC One utilizzando Tapatalk
same as ceed
comizelu (28th January, 2018)
Hi Dave, can you elaborate on that? Would that be like buying something like a blank TI 4D-6X and then being able to write initial data to it so it then becomes a 4D-64 or maybe a 4D-68? If so What tools should I be searching for to do this type of thing? Thanks for the feedback.
Any one done Honda Civic 2014 with keydiy remote? (DIYR19 KeyDIY Remote Flip (NB10-XTT-3) Honda 2013-2015)
Every time I tried to generate programme says, Please use the NB Multi-fuctional remote to generate (003D) any idea.
WD40 (1st February, 2018)
2003 lexus uk rx300 im struggling to work out which remote to pick
Add life to your days not days to your life
P
Insignia 433 remote acts as 315 after generate, with older install its good.
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
Maybe this one
https://mega.nz/#!FzgXTIxQ!QMCQLoFok...ugrRB8zcHubWvk
remember to disconnect from the net before extract the file, because it will delete the nissan file
https://mega.nz/#!0sUDiaiK!1OsXSLHyG...BayysY7rfn7RW4
newone (3rd February, 2018)
