Diagnostic Trouble Code (DTC) U0427 Definition
I think no way to "disable" to make the car start. Look why comms with security module is not working.
In fiat models there is mostly a trick to skip the crash signal and start the engine,....
This trick works with switching flash lights on off in a certain time and order ;-)
enjoy and have Fun
Tom
I try this, but don't works:
* turn ignition key to MAR;
* turn on right turn signal;
* turn off right turn signal;
* turn on left turn signal;
* turn off left turn signal;
* turn ignition key to STOP.
electrones (28th July, 2014)
it will not work if you are doing this in that order - you have to wait till turn indicator light in dash Shows you that you should Switch on Signal ;-) i also had same Problem with Fiat 500 - till i recognized to wait till control lamp Shows me in dash,..... i think description in tech book is not 100% correct ;-) hope this helps,....
enjoy and have Fun
Tom
LaraVAG (16th November, 2013)
Hi friends
I managed to redefine a rugged fiat doblo with this method very good
grateful
Cheers
Press "THANKS" button. just one click, CHEERS
Those Italians make fun of their clients, right turn signal, left turn signal, blink, maybe horn twice... turn radio on, then off... f**ck, what is the point of this exercise...
hey, giovanni....why did you go there?
hmmm....for have from where return my friend....
process e2p file on meucci and delete crash signal
fiat fiorino 100%works
do this steps with your scanner if not worked try this file
Connect the scanner to the Body Computer control unit,
& do this "Inertia switch reset (FIS)"
ecu eeprom repaired try & report
