The new OpenPLi needs you to setup a password via telnet to be able to use FTP.
Do like this:
write telnet "IP on VU" then ENTER
Then write "root" and ENTER
Next step is to write "passwd" You are here telling the box that you should change Password. So write PASSWD like this (not caps lock) and then ENTER
Now should it ask you for a new password. Then type your password you want and one more time. Telnet is telling you when the passwd is changed.
Good Luck!
What telnet tool do u recommend?
Putty always works well for me
become a member to thank you. works perfect and got every addon i need.
armstrongstreener (19th November, 2013)
Stick around here mate GREAT forum.
gregorke (19th November, 2013), SuPeRfLyiN (19th November, 2013)
Hiya, yes absolutely brilliant. Thank you much for your advice. Sort d/l putty changed password and now I can Dcc/FTP. I noticed that I don't even need a USB for EPG it seems to populate every station. Along with TSmedia just testing now. Looking really good. Thanks sgain
Does the usb stick have the be blank ?? Or can you just put the VU folder on there ? ..
I cart get this to work ... What am i doing wrong ..
I have a new box .. with just the black hole image on ..
I turn the box on with USB in and the LED turn purple .. RED & BLUE together ..
So an i uplug the usb the box boots up ???
Can this be used on cloud ibox 2 clone?
pl1976 (21st November, 2013)
Thanks for your backup does it store EPG to internal flash or USB
saves on internal flash, but will save on usb if it is avalable
