Page 29 of 37 FirstFirst ... 192425262728293031323334 ... LastLast
Results 421 to 435 of 553
  1. #421
    Jan 2018
    thank you so much ! worked perfectly
    I was using win10 and it did not work.
    I changed to win7 it worked normally
  2. #422
    auto techniek's Avatar
    Mar 2017
    Need some help.
    Can anyone decode the key.
  3. #423
    Jun 2013
    VA2 after 2010? If this is right, using the invert bitting should be. 576856. When rotating the picture 180 degrees.
    I see that it is not in the software you are using together with the machine.
    It has only only VA2 from 2002-2009 available.
  4. #424
    Mar 2017
    Hoi
    It is VA2 from a clio 3 from 2006.
  5. #425
    Jun 2013
    I think this is not an easy one. ABCDEF in heights.
    But you are quite close with putting this in your software or machine. ACB-AAD
    Customer sent you only a picture. Or you can not decode with the machine?
    Or you can cut and test until you get a working key?
    I see you rotated the picture also. Easier to read like this.
  6. The Following User Says Thank You to Weasel3 For This Useful Post:
    auto techniek (15th January, 2018)
  7. #426
    Mar 2017
    I wil try and play with it.
    I ve only a picture and key is not present.
    I m interested in reading keys bitting with the eyes and trying to learn
    Quote Originally Posted by Weasel3 View Post
  8. #427
    Mar 2017
    Are Miracle A5/A9 cutters and tracers also suiitable for v8/x6 machine?
    My cutters/tracers need to be fastened with a screw.
    What are the specification of the cutters?
  9. #428
    Feb 2017
    UK
    Quote Originally Posted by auto techniek View Post
    What are the specification of teh cutters?
    for v8/X6 has 6mm / 2mm/ 35mm long I don't know if Miracle are compatible but they are longer.
  10. The Following User Says Thank You to redliner For This Useful Post:
    auto techniek (18th January, 2018)
  11. #429
    Mar 2017
    Do you know where to buy?
  12. #430
    Jun 2017
    US
    How often does everyone calibrate their machine? Once every time it's turned on? After every key that is cut?
  13. #431
    Mar 2017
    I do it before each cutting job.
  14. The Following User Says Thank You to auto techniek For This Useful Post:
    darknezz19 (22nd January, 2018)
  15. #432
    Top Poster ramiz auto lock's Avatar
    Nov 2017
    NORTH LONDON
    I calibrate every time begir use .
    Found that the key is cut more accurate and much better
    I never used to calibrate .sometines after cutting the key was perfect on the door lock but a bit catchy on the ignition since I calibrate never have this problem.
    Sent from my SM-G925F using Tapatalk
  16. The Following User Says Thank You to ramiz auto lock For This Useful Post:
  17. #433
    Nov 2017
    NORTH LONDON
    I can see in this thread there are a lot of bad comments on this tool .
    I would like to share my experience with this tool
    I bought this tool 2 years ago and this is the only key cutting machine I have at the moment and I cut minimum 15 keys every week with it and it never let me down apart from buying cutters .
    For a £900 automatic key cutting machine i think it has done a lot more for me.
    Well happy with it even thinking of buying another one for back up
  18. #434
    Mar 2017
    Do you use machine software ?
    I ve always problems with Hu64 keys. Some time have to do the job 2 or 3 times before working.
    Quote Originally Posted by ramiz auto lock View Post
  19. #435
    Nov 2017
    NORTH LONDON
    no i just use the machine never used the software on pc or laptop.
