Results 1 to 15 of 22
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default R270 Opinion and Support Device
    Hello, I try to erase incremental area of 35080 eeprom with willem, Upa-usb and Carprog and don't work... then i thinki in bay R270 programmer, need opinion and supported Device.
    I read in forum problem With Cas4 of chassis "f" in BMW
    ttzag's Avatar
    digital-kaos
    masks support in photo, and much more
    about cas 4 only 1L15Y mask
    Actions speak louder than words
  3. The Following User Says Thank You to ttzag For This Useful Post:
    Col19 (13th December, 2020)
    Sep 2011
    In the Garage
    Quote Originally Posted by ttzag View Post
    Thanks for the info. Other question, can i read on board without security bytes??
    And about 35080 and 35160 work 100% on incremental area??
    ttzag's Avatar
    digital-kaos
    All works in circuit, no adapters with it
    For me Not good for 908
    35080 ... . .never failed me .
    Sent from my HTC One using Tapatalk 2
  6. The Following User Says Thank You to ttzag For This Useful Post:
    ruffles1986 (7th December, 2013)
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    I tested R270 and I must say that works very well M35080 and 080D0WQ,mcu like hc908 in VW,Renault airbags,EZS W203,W211,...M35080V6 not tested yet.
  8. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    ruffles1986 (13th December, 2013)
  9. #6
    salkapone's Avatar
    Oct 2013
    i tested ,,,,work perfect...heheh
  10. #7
    i tested r270 on m35080v6 ,, works great
  11. #8
    Aug 2015
    Mars
    all of you,may i know which R270 you all buy?
    Blue color case, or metal case, have link?
    Sent from my CHM-U01 using Tapatalk
    IF I HELPED CLICK "THANKS"
    MVP pro,Tango, TMpro, SKP900, X100pro, i80pad, Mbtool, VVDI prog, KD900, Mini900, Ad900, Ts888, Ak500+, AK90, BMW Multitool, Xprog clone, miniprog, ETL, wellon vp380
  12. #9
    rob h's Avatar
    May 2011
    I have the black plastic from obd2express, it is good.
    I also have a vvdi prog. And i enjoy getting the updates.
    You can download the vvdi prog software and run it, this will give you a idea. version 4.2.0
  13. The Following User Says Thank You to rob h For This Useful Post:
    haiz0708 (10th January, 2016)
  14. #10
    For all 35080 100% work
    For 912 work 100% but for 68hc08 no work .
  15. #11
    electronistul21's Avatar
    Nov 2011
    galati,romania
    work fain to 35080 and 080DQ.good tool.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  16. #12
    Jun 2016
    not all R270 are good, i buy since 2 years on ebay. M35080 not read, after rework and help from other forum members read but not write.
    CAS1,2,3 and 4 works fine.
    i think you can have luck or not.
  17. #13
    Sep 2015
    R270 is a lotery.
    in some cases:
    R270 not read M35080
    R270 not read cas
    R270 kill ezs
    R270 kill cas.
  18. #14
    miha99's Avatar
    EU
    I tested R270 M35080 and 080D0WQ OK
    M35080V6 no go.
  19. #15
    intell's Avatar
    My R270 after a few uses don't work with 35080 memory.
