Skylanders Swap Force Portal not working - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    DK Veteran bowie's Avatar
    May 2009
    God's country
    i think its the game itself as others are having similar problems. try disconnecting your wii from the internet or, at the point where the game freezes try playing with one non swap force skylander. this could be a problem activision needs to sort out.
    you could also try unfolding the usb cable completely and placing the portal away from the wii. or lastly try freeing up about 1500 blocks on the wii
    Men of Harlech onto glory
    This shall ever be your story
    Keep these fighting words before ye
    Cambria will not yield
  2. #17
    Dec 2013
    I'll keep it in mind, thank you. I switched from 223 to 247 and it seems to be working great so far. Time will tell...
  3. #18
    Jan 2014
    Thanks Keithuk: you procedure worked a treat !
  4. #19
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK ftual.
    I prefer you click the Thanks button as that is logged.
    Keith
    2010 Golf GTD (170)
  5. The Following User Says Thank You to Keithuk For This Useful Post:
    Throwaway8430 (7th February, 2021)
  6. #20
    Feb 2014
    Default Skylander swap portal doesn't work
    Hi folks,
    I have a similar problem where the Skylanders swap force portal is not recognized .
    I followed Kethuk instructions but the portal still shown as disconneced.
    Please help !!!
    following is my syscheck:
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 77522611
    Boot2 v3
    Found 155 titles.
    Found 52 IOS on this console. 2 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v5
    MIOS v10
    Report generated on 2014/02/28.
  7. #21
    Aug 2010
    England
    Welcome to DK rshemtov.
    I don't see anything wrong with that sysCheck only PriiLoader 0.7 is missing, add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
    Keith
    2010 Golf GTD (170)
  8. #22
    Feb 2014
    Priiloader 0.7 installed. problem still exists. Syscheck log:
    Region: PAL
    Priiloader installed
    Hollywood v0x11
    Boot2 v3
    Found 157 titles.
    BC v5
    MIOS v10
    Report generated on 2014/03/02.
    Thanks for your support
  9. #23
    Aug 2010
    England
    As I said:
    Quote Originally Posted by Keithuk View Post
    This game uses a USB portal which you get when you buy the game.
    Keith
    2010 Golf GTD (170)
  10. #24
    Apr 2014
    Default Hi having similar problems here also
    Have tried to follow the above mentioned steps but the portal is still still coming up as not detected.
    Using USBLoader GX and have the actual portal.
    Syscheck is as follows:
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    Region: PAL
    System Menu 4.2E (v482)
    Drive date: 2008.07.14
    Homebrew Channel 1.1.0 running on IOS61
    Hollywood v0x21
    Console ID: 128496313
    Boot2 v4
    Found 114 titles.
    Found 55 IOS on this console. 5 of them are stub.
    IOS3 (rev 65280): Stub
    IOS11 (rev 16174): Trucha Bug NAND Access
    IOS16 (rev 512): Stub
    IOS20 (rev 16174): Trucha Bug NAND Access
    IOS30 (rev 16174): Trucha Bug NAND Access
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS50 (rev 16174): Trucha Bug NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS60 (rev 16174): Trucha Bug NAND Access
    IOS70 (rev 16174): Trucha Bug NAND Access
    IOS80 (rev 16174): Trucha Bug NAND Access
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access
    IOS223[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    BC v6
    MIOS v10
    Report generated on 2014/06/22.
    Any ideas on where i'm going wrong would be great!
  11. #25
    Jan 2015
    He Keithuk,
    I followed this guide exactly, or at least I thought I did. Here is my sysCheck, do you see anything out of sorts? I'm still getting the error that the portal is disconnected.
    Region: NTSC-U
    System Menu 4.3U (v513)
    Drive date: 2006.05.26
    Homebrew Channel 1.1.2 running on IOS58
    Hollywood v0x11
    Console ID: 34783004
    Boot2 v4
    Found 121 titles.
    Found 55 IOS on this console. 4 of them are stub.
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS90 (rev 54321): Trucha Bug
    IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS254 (rev 65280): Stub
    BC v6
    MIOS v10
    Report generated on 2015/01/06.
  12. #26
    Feb 2021
    As you may have read on here thats a typical sysCheck of a Wii thats only been softmodded as you have originally showed 16 IOS's that are Stub. You do have IOS36 and IOS236 that's all but you need to reduce that 16 down to 4 or 5.
    Download ModMii6.3.0 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Install all wads with Multi Mod Manager (MMM) should be the first app listed select it and load it.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    If you have to update to 4.3 then the Shopping Channel may work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
    Do another sysCheck to make sure everything installed correctly and post that.
    Cool, this advice still works in 2021. Some pointers for other latecomers. Follow Keithuks advice closely, it's easy to overlook crucial steps. For me, I thought Modmii would copy the relevant files to the SD card, but you have to do it manually. The links don't work anymore and MMM and the IOS236 Installer are not included.
    d2x v8 Final wad pack: http://www.mediafire.com/file/x4mf58...final.rar/file
    Multi Mod Manager: https://gbatemp.net/download/multi-m....13015/history
    ModMii: above link still good.
    IOS236 Installer: https://sites.google.com/site/comple...attredirects=0
    I finally got Skylanders Swap Force working, on 4.3E, after installing the Final Wad pack. I run the game with USB Loader GX on cIOS 247 or 248. With cIOS 222 or 223 the portal lights up but the screen stays black.
    Good luck!
