makura (17th December, 2013)
gepakg
Can you help me synchro V50
http://www.digital-kaos.co.uk/forums...43/index3.html
gepakg thank you very much
ABS SERIAL NUM 000050047339
Please can you help with ecu synch for the two files CEM and ECU for S80
I?m not on my work computer so can?t mod yet your ecu eeprom since I don?t have any reference files...
But here is some info on immo sync and key codings to see how the patterns go.
Cem sync is found from 61FA to 6205: 03 B9 90 53 35 72 41 62 86 17 5F 00 --> converted to numbers 03 53 90 72 35 62 41 17 86 00
Key codings are on row 6210 to 621F. 2C B0 0C FD 42 5D BD 60 41 5A FB 89 00 23 00 00 Key 1: 2CFD0C5D Key 2: 4260BD5A Key 3: 4189FB23
arti1 (30th January, 2019), artkiani (30th December, 2020), chriskross (29th December, 2013), gepakg (29th December, 2013), jurik8 (16th January, 2017), konop11138 (3rd January, 2019), makura (29th December, 2013), spacebiker (27th August, 2017)
chriskross (30th December, 2013), makura (29th December, 2013)
Need sych for a S60,can any one help.
ABS serial 000050263663
Car cranks but will not run.
On Volvo 99-04 you don't need abs number!
Only sync cem to ecu
And keys in cem
Christian Johansson via Iphone 5s
If you use diffrent software so remember that volvo has diffrent canbus and many diffrent ecu (even same number on ecu = diffrent canbus)
Do check by vin in vida so you have correct oem number when you use used ecu!
hpsyndicate (22nd July, 2015)
does anyone help me to get CEM and ECU files for Volvo XC70 2.5T of the 2004?
CEM uses 28F400B5, ECU uses 95P08 eeprom.
hello
I have the same defect in a volvo s80, could you set me free winzip password to run the car
