Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    Jun 2010
    Austria
    Yes, BMW CAS4 ver 1143 or higher not ok.
    This is also confirmed with chines key tool checker, if higher also cant make key... but who knows
  2. #32
    Nov 2009
    CAS4 + Programmer
    And this tool? Anyone tested?
  3. #33
    davecooper47's Avatar
    Dec 2010
    Looks brilliant. It can even program the CAS 4 in the F30 and F20 (3 series and 1 series). I'm going to order one right now. I'll let you all know how I get on.
  4. #34
    Dec 2010
    Quote Originally Posted by davecooper47 View Post
    Its dont work its the same like codiprog mk2
    just in the plastics black box.
    so dont order
  5. #35
    Dec 2010
    F20 F30
    there is no cas4 5m48h there is FEM module.
  6. #36
    Jul 2010
    GB
    Is this Codiprog resurrection thread dead???
    Markony, will you share with us what have you done to your Codiprog interface? I understood you changed parts, can you be more specific what parts were changed?
  7. #37
    Aug 2012
    Its don't work only early version
    There is only one programer that work 80%
  8. #38
    Apr 2010
    Portugal
    Quote Originally Posted by alex1975 View Post
    So??
    Tell us!!
    Regards
  9. #39
    Dec 2010
    You can find in this forum the name
    of this programer.
    its cost about $1700
  10. #40
    Jan 2010
    j-tag from smok its thats bad?? What programmer is worth to buy now to do cas4?
  11. #41
    amir_82013's Avatar
    Jun 2010
    Xprog ELDB Co. (Original)
    with good support : info.ELDB@gmail.com
    http://www.eldb.eu/
  12. #42
    Jan 2010
    Quote Originally Posted by cheester View Post
    When use jtag from smok; not use standard coax cable but make 2 wire twisted pair (12-15cm).
    It increase the risk to erase d-flash a lot.
  13. #43
    Dec 2010
    That was i told to smok support
    i did like this and read cas4 5m48h successful
    with twisted wire 12 sm.
  14. #44
    Jan 2010
    Quote Originally Posted by rukartinatv View Post
    So you did good engineering work.
  15. #45
    Its mean that now your smok work correct with 5m48h?
