Results 1 to 8 of 8
Thread: Pinout edc16c9
    Default Pinout edc16c9
    Hello! I need to reset a edc16c9 of opel but i dont have the pinout. Someone have hese? Thanks!
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Quote Originally Posted by GaizkaV8 View Post
    PIN 2,4 and 6 to Ground
    PIN 1 and 5 to +12V
    Can High pin 84
    Can Low pin 83
    Can use imdec 3.2 to virginize too.
  3. The Following User Says Thank You to ruffles1986 For This Useful Post:
    GaizkaV8 (23rd December, 2013)
    thanks!!!!
    May 2014
    Belgium
    Quote Originally Posted by ruffles1986 View Post
    PIN 1 and 5 to +12V
    Can High pin 84
    Can Low pin 83
    not working, dont have connection
    tinchocbr's Avatar
    In my house
    1 - 3 -5 - 28 (+)
    2- 4 - 6 (gnd)
    diag line K 25
    85 (H)- 84 (L) CAN line
    All conector K or 94 pin
    This conecction is for GM S10 or captiva in Latin America
    Hi.
    I need to read the file, but do not know,
    which tool to read or write this ecu.
    thank you.
    Apr 2016
    MOROCCO
    Oct 2015
    Default I think the pins of the BDM, are the reverse.
    The position does not match the pins of a BDM connector
    They go with that position
    Error?
    I have checked the pins of the ECU in the BDM, and the pins correspond to this position, the positive ones and the negative ones
    I have already found it, thank you
  10. The Following User Says Thank You to Da95br For This Useful Post:
    garric (1st November, 2023)
