sirius 32N immo off
Hello mates,
I have a Renault Megane 1,6 16V with AC and it's Automatic gearbox.
It has a Sirius 32 ecu with CAN with part number S110010002B 7700114504
Is there a way to make this ecu immo off? As far as i've seen this ecu can't take an emulator! Is there another way?
Thanks in advance for your help
sirius 32N immo off
Thanks a lot!!!
I will try it and report!
I have just got news frm the client!
The car starterd ok,, immo light flashes but the automatic gearbox is not working! It works only with one gear,, and it won't change
alessio93 (15th March, 2018), kugglefischer (17th March, 2016)
The ecu has the 8pin smd chip on the top left side,, that means it's can right?
Here's the flash of it!
Renault_sirius32CAN__28.12.2013.rar
bole1978 (18th October, 2021), cruznarvaez (24th September, 2019), cruzpablo (6th August, 2018), elmassryelectro (28th March, 2020), i_shot_the_sheriff (31st December, 2013), kugglefischer (17th March, 2016), MOBILTRONIC (19th January, 2020)
I'm really thankful!!!! I will try and report in a few hours!
Just wanted to ask,,, should i cut the immo wire?
alfredoesp23 (5th April, 2019)
It worked like a charm!!!!!! THANK YOU SOO MUCH!
Thanks alot Lupu..... ;-)
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
hi friends, i have the same problem whit same unit can someone can help
siemens sirius 32
s110010002B 7700114504 THANKS
immo off please
someone can help please
test and the result
thank you if I helpedgratitude motivates me to help further
Ermakbrat (17th May, 2019)
no works,is possible someane can help thanks
