    Default Bricked dm500hd or not?
    After installed new bootloader sim2_500HD_ssl84_0929, my box stays unconnectable.
    I can't connet through web browser by holding in the stanby button and powering it on.
    The green light stays green and doesn't flicker as it should when it gets a new dhcp ip number.
    What can I do to sav it. Since it wont reeboot to the old image after I loaded the sim2 image mentioned above.
    Default Drivers for 500hd for connecting with dream up.
    Where could i find drivers to my windows 7 for my dm500hd box. My laptop doesn't recognise the 500hd box without the drivers when I want to use dreamup.
    When I used sim2_500HD_ssl84_0929 after I installed the original Image oenpli, did I brick my box?
    The light stays green on the box but I cant connect with it.
    Please help.
    Default wich way to hard reflash the image in the box.
    I would be happy if someone told me wich dream up to use with dm500hd and what drivers to use in windows7 to ensure connection with the box.
    Since I'm having trouble to connect with my box through web browser I wonder how else I could connect with the box and reflash it.
    digicon's Avatar
    You bricked the Box if you loaded an official OpenPLI build as your receiver is Sim2 and so you should have loaded a Sim2 compatible image
    Also for all other problems see here: http://www.digital-kaos.co.uk/forums...nd-tut-385711/
