Results 1 to 12 of 12
    Member billybob69's Avatar
    Jun 2008
    Default 600PVR: Transferring recordings to PC
    I've a Dreambox 600PVR which I have managed to fill up the hard-drive with late-night recordings [cough!] which I now what to transfer to my PC or laptop.
    Is it possible that someone can give me an overview of how to do this?
    Thanks in advance.
    bb69
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    Ahhhh so much culture and so little time....
    Can't you just ftp the files from the location on your HDD to your PC/laptop etc... Thats what i would do.
    Jun 2008
    Quote Originally Posted by caveman_nige View Post
    Thanks for the reply.
    To FTP across, is there a particular piece of software that you recommend to use?
    Also some of the files are quite sizable - 2 hours long - do these take long to transfer?
    Thanks.
    V.I.P. Member westkill's Avatar
    May 2008
    try dreambox command centre dcc i think that is in the downloads that has an ftp program in it , just setup the ip address of pc and dreambox then it should conect
    on one side of the page you will see your pc files and the other is your dreambox
    click /media/hdd/movies on your dreambox side and you will see your recordings
    then highlight the file you want to send across to your pc to what ever file you like on your pc ,you will see two arrows in the middle for direction to send the files
    if you can understand my jiberish
    <--westkill added 3 Minutes and 40 Seconds later...-->
    Quote Originally Posted by westkill View Post
    yes dcc is in the downloads
    Last edited by westkill; 5th June, 2008 at 07:49 PM. Reason: Automerged Doublepost
    May 2008
    I just use explorer to map a network drive to \\dreambox\Harddisk and then do a copy and paste. No need to FTP anything.
    May 2008
    If you plan to ftp off recordings it's worth checking your setup n making sure the max file size for recording is 2 or 4 gig so u end up with just one file per recording.
    It's a pain having to join files. I know!
    VLC plays the ts files you ftp out perfect.
    May 2008
    Once copied across to my pc, I rename the file to .mpg and Media player will play with no problems.
    Jun 2008
    Thanks all the replies. I?ve managed to transfer the files across by FTP using Dreambox Command Centre ? so simple even I could figure how to use it!
    Quote Originally Posted by Hejira View Post
    Thanks. How do I do this?
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Maybe different for some images but on my Pli image it is Setup > AV & recordings and select the size of the file you would like to create when recording.
    Don't ever switch to satellite m8 otherwise you will go blind with all the culture.
    May 2008
    If you have a bunch of .ts files you need to concatenate together:
    Windows:
    copy /b *.ts merged.ts
    Linux, Mac OS X, etc. (could probably even do it directly on your Dreambox with telnet/SSH provided you have the drive space on the target disk):
    cat *.ts >> merged.ts
    .ts files are just MPEG-2 encoded streams so that's why you can concatenate them and why if you rename the file .mpg it'll get picked up by standard video players.
    Jun 2008
    One could also use the web interface to download the movile files
    May 2008
    Quote Originally Posted by Saruman0 View Post
    Hehe, indeed you could.
