Results 1 to 2 of 2
    Jan 2014
    Default Skybox f5s recording problem
    Can anyone tell me how to set my skybox not to turn off after recording, as it does not seem to turn back on to record if I have set another recording
    Hadron's Avatar
    Nov 2012
    E. London
    I don't think there is a way. Hopefully a newer firmware will sort this out.
    Have you ever tried setting a timer to simply change channel in between the times of the timer recordings?
    For example, if you have set 2 timers to record 6pm for an hour, then 9pm for an hour, what would happen if you set another timer for 7pm for 2 hours, but set the timer service to "channel" instead of "record"? Hopefully, that should keep the box turned on in between recording.
    I haven't tried it myself, but it should work in theory!
