Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 85
  1. #61
    Apr 2013
    Default RE: Stuck on Commando image
    Hi all,
    Sorry but would anyone know what I should do as stuck on the Commando image when I start the DM.
    Regards John.
  2. #62
    How to get back adult channels on commando 15 help will be appreciated thanks in advance
  3. #63
    Just wondering if this image can be used in North America?
  4. #64
    Apr 2013
    Sorry all,
    But can anyone please help me with my query.
    Regards John.
  5. #65
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by jonnyboy123 View Post
    Sorry all,
    Regards John.
    sounds like bad flash you will need to use dreamup
    http://www.digital-kaos.co.uk/forums...dreamup-42950/
  6. #66
    Apr 2013
    Quote Originally Posted by JoK View Post
    Read post 55 and buy a null modem cable.
    JoK
    Thank you both for the feedback - I shall buy a null modem cable ( saw one on Ebay for under ?2 ) and give it another go.
    I did actually read quite a lot on the forum before trying via the network but obviously for me it was not going to work
    Regards John
  7. #67
    thanks for image
    loaded up fine but in network settings i cannot obtain the ip address of the box, tried to restart network but no joy.
    can anyone help please?
  8. #68
    plasterer's Avatar
    Jun 2008
    Mersyside
    Have you got dhcp enabled
    If not you need to enter it manualy
    Enable dhcp and reboot the box .................Paul
    PAUL
  9. The Following User Says Thank You to plasterer For This Useful Post:
    wally6529 (8th July, 2014)
  10. #69
    hi guys ignore my post box had faulty network port, however i h ave put the image on another box which is all fine apart from how do i install the cccam plugin?
    does the image come with the plugin?
  11. #70
    Feb 2012
    Sorry to say but this image is a nightmare just updated from 14.7 to 15 through the receiver everything seemed to go great, now it's telling me there's no boutiques I've done a channel scan finds the channels no problem but now it's just locked on one
    I'll go back to the old image
  12. #71
    Junior Member suttsy's Avatar
    Jun 2013
    on Hotbird
    Hi lads,
    I'm currently in a spot of bother, I've got my hands on a Blade BM500s, which appears to be password protected.
    I have tried to FTP into it with no luck, I've tried to re-flash it with DreamUp with null modem cable without any luck either.
    I'd appreciate any help with this, is there someway of a factory reset maybe.
    Suttsy
  13. #72
    Feb 2012
    I've gone back to 4.7 which is working great, for some reason the update through the box to 15 is just too many problems from me unless I'm doing something wrong as I cannot get boutiques organised at all.
  14. #73
    Network Issue on Commando 15 C on DM500V8
    i am using homeplugs for DM500S and its running great.but on DM500V8 i flashed commando 15C which is flashed fine but on the same homeplugs it says on network settings
    dbox reachable (Ping)
    Default Gateway Unreachable (Socket Error)
    DNS Server " "
    Via IP (88.198.50.98) " "
    i put the ip address of my box manually i did DHPC off and then i put my ip address manually and then rebooted but it says what i have already mentioned.
    when i put DHPC on and reboot the box it all disappears like ip address and Default Gateway is MT
    what shall i do in this situation because when i put other box it runs fine.if some one can pm me and explain me what to do i will really appriciate it.Thanks in advance
  15. #74
    DNS Server " "
  16. #75
    hi guys
    I am using commando 15.d and when I scan, I seem to have lost half of my channels, looks like transponders and frequencies have changed. How to ensure this is all upto date for me to get all the latest channels/frequencies?
