Ok! Thank you mate!
YOUR software posted here mate http://www.digital-kaos.co.uk/forums...65/#post583893
Thanks for your time and effort !!
Ok! Thank you mate!
ah man, thank you for this, i've struggled so long
Hi will istalling the files on page 1 of this post help me workaround my hardware key in tis 2000 so i can access the "security access"?
Anyone tryed this crack on V95D?
HI i need the emulator for gm tis and i dont have an lpt port
Gm\sps does work with a Mongoose as well as TIS2WEB
General Motors (VPW/CAN)
Here's some install instructions: It will work w\SP-3
CAUTION XP Pro is the Only Supported Operating System!
When Installing TIS 2000 select the Green Dongle that is one to the very left of the 4 choices of security keys and Add it.
Please choose English and NAO and Install
Insert Data Disk and double click the Tis 2000 Icon on the desktop
When tis 2000 opens it will find the new data disk and update the system.
Next Put the Key disk into the drive.
Highlight the Goodkey.ssi and the ssipddp.sys and copy them to windows clipboard or hold the control key and hit the letter c on the keyboard.
Nothing will happen when you do this but that is normal.
Next right click on the start button and choose explore
Browse my computer and locate the windows folder and select it.
Next browse windows folder for the System 32 folder and select it.
Next Browse for the Drivers folder and select it.
Next paste the 2 files above into the drivers folder or hold the control key and hit the letter V on the keyboard.
It should ask you to overwrite the files and please say yes to all
Reboot system.
Put in the <system root>\system32\drivers folder.
Reboot. This is a software key.
Example C:\windows\system32\drivers
Over write any existing files.
Make sure you reboot the PC
Enjoy!
If this doesn?t work make sure your printer port in the bios is on and set to ECP.
Also make sure if you are running a Pentium 3 processor you need the patch that is on the key disk. Do not use the patch if you have any other type of processor.
Also if you are installing this on a laptop make sure you have a serial port on it as it won?t work through your network card.
Also if you are using an AMD athlon processor you could also have issues, this is made for intel systems only.
This is a stand alone program made to run on a stand alone pc with no other programs running so make sure all TSR?s are not running when trying to install.
Also Disable your antivirus.
to do a clean uninstall:
TIS Uninstall Procedure:
Uninstall TIS 2000 First by choosing start programs TIS 2000 uninstall.
Let it uninstall
Reboot system
Right click on the start and go to Explorer.
Find you C: drive
Find the c:\programfiles\cosids and delete the whole cosids folder.
Go to Start then RUN type REGEDIT hit enter
Click on HKEYLOCALMACHINE then SOFTWARE then Delete the folder called GM.
If there are other gm folders leave them alone.
Click on START then RUN and type SYSEDIT Go to the AUTOEXEC.BAT file and look for a file that says SETPATH=%PATH COSIDS\PROGRAMS\COSIDS OR something close to this. If you find it, click just in front of the first letter of the SETPATH and type REM then hit the space key once. Then save and exit.
Click on Start and Search (or find files or folders) on the c drive and type in COSIDS*.* and hit enter
Delete any COSIDS files that are here.
Make sure you are searching the c: drive.
Empty the Recycle bin
Reboot the PC
Reinstall TIS 2000
For Mongoose setup:
1) Click on the configuration drop-down menu and select IO
Management
2) On the IO Management screen, click DRIVER to add J2534
support to TIS. In the INSTALL DRIVER box, type or browse to
c:\program files\cosids\bin\j2534.dll and click INSTALL. This
will install the driver and bring you back to the IO management
screen.
3) On the IO Management screen, click ADD to add the new
interface. For the LOGICAL NAME type ?Generic Pass Thru? and for
Driver choose ?J2534 Pass Thru Driver?. You must type the LOGICAL NAME exactly as shown with
a single space between words and capital G, P, T. If you mistype even one character or miss a space it
will not work.
4) On the IO Management screen select 'Generic Pass Thru', click PROPERTIES and choose a
specific J2534 device. In the DEVICE NAME list choose YOUR J-2534 device. Return to this screen
if you want to change to another J-2534 device later.
5) Close I/O management and choose Service Programming
System. Use the new GENERIC PASS THRU option as your
diagnostic interface.
If you have a P-3 machine you need this patch only install on a P-3 (see .zip file)
If you do not have a lpt port you are S.O.L.
If this helped you please hit the red thanks button.
jmn (12th August, 2016)
I have tried every way that has been posted, When I get to Data Transfer, Tis just freezes, never starts the transfer.
Anyone else have this issue? anyone resolve this issue?
if the hardware number isnt recognised, start a reflash procedure on original ecu but switch ecu's before you hit the "do-it" button. It works as long as it is a REAL equivalent replacement.
Does the above file work with the opcom device for making changes to a saab?
hy i like this information it is great
