Can some one tell me what I have to do for download this software. When I try to acces to the download link. It say ' You don't have permission, or you are not logged in.
Help please.....
Help please.....
is id work with all GM TIS2000 ?
I need your help!
I have installed TIS 2000 NAO (TIS2000 NAO 11/2006) and I have no problem to update Tech2 with GM software.
I have problem to update calibrations into Chevrolet Trailblazer 2004 for Transfer Case module. I did following steps.
1. Update Tech2 with GM software.
2. Connect to vehicle Tech2.
3. Select menu item 2. Special functions.
4. Download to Tech2 vehicle data.
5. Connect Tech 2 to PC.
6. Select module programming.
7. Read data from Tech2. In result TIS showing correct VIN taken from Tech2.
8. Select TCM module replacement.
9. And in moment when software and callibrations have to be uploaded to Tech2. I see only screen blink and I see next menu item "Select module for programming".
Do you have any idea or may be I have to install older version of TIS to perform this operation?
Thanks for your advice,
Andris.
i need tech 2 china clone dump...
Thank you
Do I need a usb dongle to make TIS2000 work with tech2 ?
IF you talking about Opel - Vauxhall = NO any USB Dongle, NO any Dongle "Pill", just & only you need:
Opel - Vauxhall GlobalTIS
(Off-Line SPS, Security Access, S/W Download to 32 MB Card, etc...)
Use Google and you will discover Info & the S/W...
Regards!
Thanks, a lot of learning.
Is there anything less in the newiest version of TIS? My last version contains service information, circuit diagramms and a third object, I just not hit on.
Greetz
thanks, good job
I have TIS2WEB account i brought it for one year , the latest tech2 software is :
VersionRelease Version
Saturn Astra 30.001
NAO 30.007
SAAB 146.000
Holden Export 122.001
Please can someone give me a link to GLOBALTIS SAAB? Thanks a lot for any info.
