asid12
orig message about tech2 transfercase module program.........
sorry i am new just trying to get in conversation
did you find fix for your problem may be firmware change as gm changes module manufactures hope this helps
asid12
Work great .thanks very much
is good the tech 2 clon?
someone have experiense with this clon
I Tried the TIS Crack no Dongle file that download from this post . but i am unsuccessful to use the TIS2000 For programming with my Chinese Clone GM Tech 2 . it shows "communication could not been establised " ? Anybody can advise me ? Is the Chinese clone Tech 2 do the SPS programming job ?
So far I haven`t have any problems with my Clone (hehe) even when bought, the seller sad it is orig,,,,,, but never did or even if did then don`t remember, SPS (programming ECU, etc.)
Just 3-5 days ago I had to buy 2 day $55 subscription from GM to program ECU on Chevy Malibu, because my Software hangs at the downloading (to the Tech2 an update file for the VIN) screen with no answer......
I`m trying to get some support from the seller.
Installed it on another computer with the same issue
So, now I did the Tech2 connection test from within TIS2000 window and it shows me that I don`t have a driver for it. Didn`t try it on another mashine yet, no time to play around too much
Used Clone with the subscription to program the ECU and from the second try it worked!
$55.........................
Sigh...............
It seems that the clone gm tech2 could not communicate with the TIS2000 programmer installed in the windows xp . so i just wonder whether the clone one have the ability do the service programming system job. anybody have the good experience ?
Does the serial port work?
My tech 2 clone serialport didn't work. I had to change max232 in the tech2
To get a clone working properly you need to replace the communications cable supplied by the chinese with a regular TP(cat 5) network cable and a PCMCIA Linear 5/12v flashcard. Cards supplied from china is not the correct type and will not be programmed in the Tech2
I had issues on a Win XP Sp3 machine as well, could not connect. Had to go back to Sp2!
GlobalTis is also working a lot better than Tis2000
i got clone tech2 about 2 weeks ago from china with tis.tech 2 wont hook up with tis,after few uses tech 2 wont coumicate now with any vehicle,did self test on vci failed GRD tranisister test,vci is shot,now have to send it back to china,they claimed they have good quility gm tech2 yes it was good for only 2 days,junk..for programing good to get mdi,is faster then tech2 and stable.
I need your help to the elucidation of this connection scheme.
merci
Mine broke after 30 days and I sent it back now china customs will not release it since the reciver does not have a inporter number to chine so be careful when you do buisness with china
Hi all
I'm new around here, Looking for the gm TIS 2000 Version and a dongle emulator that will allow for SPS programing. Can anyone help out? I have a tech2.THANKS IN ADVANCED
