Results 1 to 7 of 7
    Member hadrian's Avatar
    Feb 2010
    Default Audi a6 3.0 tdi asb edc16cp34 dpf
    Hello. Ecu read and write by bdm. Car do not accept regeneration or reset dpf to new. Dpf off by switch in flash. Shoot level reset to zero with ecusafe. Checksum calculated after write by bdm.
    Car start, dpf clogged error disappear but i have U0301 Software Incompatibility with Engine Control Module, lamp on and no power.
    Please help me
    edc16cp34.rar
    taras_rx7's Avatar
    Mar 2010
    Disconnect all dpf sensor (diff press ,temp ) and enjoi.
  3. The Following User Says Thank You to taras_rx7 For This Useful Post:
    hadrian (1st February, 2014)
    Babos's Avatar
    Mar 2012
    +100 many times is see that
    Feb 2010
    After some km i have internal eeprom error. For the moment only temperature sender G235 and G448 is disconnected.
    I will put back the original eeprom. Please verify my eeprom because ash reset is made with ecusafe. Seems modifications is not ok.
  6. #5
    Top Poster totalfree's Avatar
    Dec 2009
    Hi.
    Your file DPF OFF
    Press the button if my post was helpful.
  7. The Following 2 Users Say Thank You to totalfree For This Useful Post:
    hadrian (12th February, 2014), pedro made (11th January, 2019)
  8. #6
    Feb 2010
    Thanks totalfree but my flash file is ok. Eeprom modifications by ecusafe is not ok. But is not necessary.
    With my file and disconnection of differential pressure sender and exhaust temperature sender car is ok. Thanks again taras_rx7.
  9. #7
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by hadrian View Post
    Please help me
    edc16cp34.rar
    Try changing 1EE5F8 from 00256 to 00000. This may work.
