Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
  1. #31
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    After a view tests i think something is wrong with this solution.Just after flashing device I try to get down counter to 250 then use Elchip solution and everything was ok,but when I used view times just to read some chips suddenlly couter reset to 61.After all I was trying usb reset and it was ok,but again after using view times comes back lib file error.Like now i decide to stay with normal Jlink flashing.Maybe only my carprog heave problems like this I just dont know.
    Regards.
  2. #32
    Top Poster aflou's Avatar
    Jun 2009
    Aflou Algeria
    hello
    usb solution don't work for me LIB file error
    i have 4.01 version old LIB
    now i tree the jtag method
  3. #33
    drewdom's Avatar
    Aug 2010
    I think this is work when couter is closer to 0.It was at first time when I used this method.I will test when comes to viwew countes to zero and give info.BR
  4. #34
    Jul 2010
    Earth
    Caused a LIB file Error in my CarProg almost immediately. Had to JTAG program it to revive it..
  5. #35
    DK Veteran elchip's Avatar
    Nov 2009
    EU
    Quote Originally Posted by aflou View Post
    hello
    You need reflash with JTAG when have that error
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  6. #36
    Apr 2011
    If I have later version than 4.01, do I have to downgrade first?
    After program with this version can I update again?
    Thanks in advance.
    Regards,
    Jules.
  7. #37
    Top Poster acaducati's Avatar
    Apr 2010
    Serbia
    Working 4.01, great. I reset the counter ...
    Thanks.
  8. #38
    bangreno's Avatar
    Oct 2011
    Quote Originally Posted by acaducati View Post
    Thanks.
    The better solution is to flash AT91 with jtag.
  9. #39
    lkjubaking's Avatar
    Feb 2013
    Serbia
    I agree with bangreno
  10. #40
    Apr 2014
    agree with above...and keep v4.74...
  11. The Following User Says Thank You to Shemek For This Useful Post:
    PierreTheron (9th February, 2016)
  12. #41
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    thanks it works 100% in carprog clone 4.01 081105CAR001773I.lib
  13. The Following User Says Thank You to jomberykaso For This Useful Post:
    Music73 (9th November, 2015)
  14. #42
    Sep 2013
    ..... it worked very well again....thanks again!!!
  15. #43
    Nov 2015
    Hi i have a problem with my carprog 4.74 with cable reset . When i connect to reset the atm91 don't connect . Cable is good
  16. #44
    DK Veteran sorgun's Avatar
    Dec 2011
    t?rkiye yozgat
    Default error
    Please help I got this error on my carprog
  17. #45
    Jan 2016
    ATHENS
    hello again
    thanks for your reply and for your information
    for your experience do you think when carprog read ffff without numbers and very time no responce unit problem become from pcb or from adaptor?
