MCU MC9S12D64 of LCM BMW e46 SW 4.5 needed
Results 1 to 13 of 13
    Feb 2014
    Default MCU MC9S12D64 of LCM BMW e46 SW 4.5 needed
    Hi there,
    my MCU MC9S12D64 of my BMW e46 LCM is burned, so i had to replace it. Now I tried to get the dump of my old MCU but it was completly defect. So I hope someone has an actual dump of the whole MCU with Software version 4.5 or earlier if there is one. I want to program the chip with my xprog-m. Maybe there can be given some informations about wirering and so on.
    Thank you so much.
    Top Poster Evaldazj's Avatar
    Quote Originally Posted by prog View Post
    Hi there,
    Thank you so much.
    why so much trouble? Buy secondhand lcm, code with ncs expert, and rewrite vin with P.A.soft
    If post helped, allways hit thank's
    Feb 2014
    Hi!
    Getting a second hand lcm with SW4.5 is in my country not so easy and cheap. So, with my xprog and the new MCU I have it's nearly priceless, if I had a flash and eeprom dump of lcm.
    smokey08's Avatar
    Essex, UK
    I forgot to reply to your pm. My LCM is HW24 SW36. I havent read flash from it.
    Feb 2014
    Alright, doesn't matter...maybe another has the right one for me...
    found something, maybe usefull for you
  7. The Following 2 Users Say Thank You to Evaldazj For This Useful Post:
    frishka (22nd March, 2019)
    Feb 2014
    Its a pity, because its just the eeprom part of mcu...that i already could found, but i need also the flash part of the mcu, because there it is the program...the eeprom only contains the coding data, the mileage and the vin...but thanks also....
    Feb 2014
    If there is someone with Xprog-m and a LSZ with 4.5, I can give some pictures with contacts on the board, so it don't has to be soldered directly to the chip...it's tested and works.
    Please, I hope, there's someone who could help...
  10. #9
    Feb 2014
    Problem solved Thread can be closed or deleted. Thanks.
  11. #10
    Lithuania
    maybe someone still hawe 4.5lsz eeprom and flash dumps?
  12. #11
    Apr 2017
    hi, can you please share that pictures?
  13. #12
    ohkarol's Avatar
    Oct 2010
    PL/UK
    here is flash in xprog format and virgin eeprom for lcm sw4.0 cl36
    bFlash/Kess/Ktag/CMD Master
    DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
  14. The Following 4 Users Say Thank You to ohkarol For This Useful Post:
    driiven (8th October, 2017), markmich (14th May, 2020), MeMpHiSj (14th April, 2017)
  15. #13
    Oct 2020
    Anyone with VVDI that could dump the flash from a CI36/37 LCM?
    I went to a guy who told me he'd program it, only to find out that VVDI apparently doesn't work with xprog BIN or C19 files since they read the whole 2mb dynamic memory block, and VVDI doesn't know how to load that to a 64kb flash (removing blank code)
