Cuberevo / mini Emulators - Page 2
Results 16 to 30 of 45
  1. #16
    Member grizzlyt's Avatar
    Oct 2008
    Default IncubusCamd ver 0.8.3+ NewCS 1.66
    NewCS - 1.66 RC1
    Changelog
    v.1.66 RC1
    All cdks are new, due to server crash.. many many changes to libs etc.
    Support for TNTSAT.
    Experimental support for *** 0963. NB! Remember to put the 4 byte hex boxkey in config!
    Multi-realms added to chameleon.
    Support for pin-code on specific channels specified by in config.
    Added the ability to disable/enable certain virtualcards on chameleon in config, or disable whole list.
    Quote:
    NB! NewCS has gone green - removed all support for windows
    Time to grow up, get a powerfriendly little linux-device to run NewCS on!
    coming soon on our panel...
    wait please
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  2. #17
    May 2009
    Default cant get softcam to work
    hi all i cant get the incubus to work.. cant dowload plugins in the black pearl img.
    and the incubuc 5 don?t work .
    please help..
  3. #18
    aftermath's Avatar
    Mar 2008
    I take it its a Kathrein box you got ?
  4. #19
    May 2009
    Default Config
    Please find config as requested, I am never sure if you can remove all the garbage and just leave the server details:
    # incubusCamd configuration file #
    # All configuration options in this file observe the same format: #
    # <configuration_name>=<configuration_value> #
    # Each section are [<section_name>:<option_1>:<option_x>] like. #
    # No matter about white spaces on any place or UNIX/DOS style files #
    ########################### general configuration ############################
    [General]
    # Enable (1) or disable (0) background execution
    # 0 - Off
    # 1 - On
    background_execution=1
    # This sets the level of console output for debugging:
    # 0 - No debug messages, 1 - First level debug messages, 2 - Second level debug messages,
    # 3 - Print all debug messages
    debug_level=1
    # This option enables (1) or disables (0) the writing of debug information to the
    # console.
    log_to_console=1
    # This option enables (1) or disables (0) the writing of console output to a log file
    log_to_file=0
    # When log_to_file is set to 1, this is the path and filename to write console
    # ouput to.
    logfile_name=/var/bin/incubusCamd.log
    # Used to activate on-screen messages. Username and password required if
    # HTTP authentication is enabled on enigma.
    on_screen_messages_show=1
    on_screen_messages_username=root
    on_screen_messages_password=
    on_screen_messages_key_update=1
    on_screen_messages_wait_for_key_update=0
    on_screen_messages_ecm=0
    on_screen_messages_emm=0
    #When activated, camd will listen on the specified port for connections. All
    #log activity will be broadcast in real-time to connected clients.
    console_logs_broadcast=1
    console_logs_broadcast_port=666
    ############################ caid configuration ##############################
    # First of all the cam use the incubusCamd.prio file, then use the
    # configuration below.
    # Sections are defined by the value of the CaID.
    # You can choose the default ecm table used by the codify, this means that
    # you can choose the first byte of the raw ecm that is downloaded from sat.
    # If you don't know what value to insert, use "80". (all value are in hex)
    # Default value for ecm_table is 0x80.
    # The option "priority" tells if one caid should be selected before try
    # another one with a priority value greater.
    # The less is the value the greatest is the priority. Choose from "0" to any value,
    # priority value is decimal.
    [CaID:0100]
    ecm_table=80
    priority=1
    [CaID:0500]
    ecm_table=80
    priority=1
    [CaID:0600]
    ecm_table=80
    priority=1
    [CaID:0919]
    ecm_table=80
    priority=1
    [CaID:093B]
    ecm_table=80
    priority=1
    [CaID:0B00]
    ecm_table=80
    priority=1
    [CaID:0D00]
    ecm_table=80
    priority=1
    [CaID:1700]
    ecm_table=80
    priority=1
    [CaID:1800]
    ecm_table=80
    priority=1
    [CaID:2600]
    ecm_table=80
    priority=1
    ########################### provider configuration ###########################
    # All parameters are in hexadecimal notation.
    # Each section is defined by the provider id value.
    # If you don't know the provider id value then use the provider id "000000" and ca id "0000".
    # On provider 000000 caid 0000 goes all provider wich are not declared. If the provider
    # is declared then the cam will use the provider founded.
    [Prov:000501:CaID:1833]
    # Decoder type indicates whether the cam will attempt to decode this provider
    # in software, or through a card-server. Supported values are:
    # 0 - Use internal softcams.
    # 1 - Connect to a card sharing protocol card-server.
    decoder_type=1
    # URL of card-server to use, formats are as follows:
    # newcamd://<username>:<password>@<hostname>:<port>/<des_key>
    # aroureos://@<hostname>:<port>
    # radegast://@<hostname>:<port>
    # Example:
    # newcamd://foo:bar@192.168.0.100:12345/0CE3476FF2E1C9D9A0A109B371E3
    # Multiple card-server url's can be specified for server fail-over.
    # If the emu fails to connect or fails to get valid CW's, it will try to
    # connect to other servers in a round-robin fashion.
    # Up to 16 servers can be added from index 0 to 15.
    # You can choose also to select a cccam or gbox server, but they must be declared
    # in the "servers configuration" section ( [Servers] ).
    # e.g. : if you want to use a cccam server for a provider you must put it on
    # the parameter card_server_url_0=cccam://
    # NO MATTER the value after the double slash because server configuration is
    # made in the section [Servers].
    # Only for newcamd, radegast and aroureos is usefull to put correct connection
    # parameters because they are provider dependent.
    # Example i want to use mine card into the slot with newcs for prov 0501 on nagra3 (caid 1833)
    card_server_url_0=newcamd://usernameassword@192.168.0.100:10550/0102030405060708091011121314
    [Prov:000000:CaID:0000]
    # this provider is a stand-in for all cards and all caid not declared previously
    # For example I choose to use cccam protocol on all other provider.
    decoder_type=1
    ########################### servers configuration ############################
    [Servers]
    # This is the section for the multi-server configuration.
    # cccam://brianblythe2006:ser732009@xxxxxx:12000/<receive_emu_shared>/[EMM]
    # where <receive_emu_shared> should assume value "yes" (without quotes, if you like to receive emus data shared by the server) or "no" (this is assumed by default)
    # gbox://<localhost>:<localport>:<password>@<peer_address>: <peer_port>:<peer_pass>/[EMM]
    # NOTE: The "EMM" suffix is optional and tells the card-server client whether
    # to send EMM's to the card-server or not. Enabling or disabling this only
    # has effect if the card-server is configured to accept emms from this client.
    # NOTE 2: The "card_server_url" is not the same as previously declared in the prov/caid section
    # use how many server as you like
    card_server_url=cccam://brianblythe2006:ser732009@xxxxx:12000
    card_server_url=cccam://<username>:<password>@<hostname>:<port>
    card_server_url=gbox://<localhost>:<localport>:<password>@<peer_address>: <peer_port>:<peer_pass>
    ########################### CaIDs tunneling configuration ############################
    [CaIDTunnel]
    # All values are in hex notation
    # In this file you can configure what CAIDs/PIDs incubusCamd should tunnel to another CAID
    # situation 1: this caid, all idents, on all channels will use the tunnel_caid
    # caid:tunnel_caid
    # situation 2: this caid/ident pair will use the tunnel_caid
    # caid:tunnel_caid:ident
    # situation 3: this caid/ident pair, on channel 'sid' will use the tunnel_caid
    # caid:tunnel_caid:ident:sid
    # i.e:
    # 1833:1702:000000:0082 # this one should tunnel premiereHD nagra3 into betacrypt cards
    # 1833:1702:000000:0081 # this one should tunnel premiereHD nagra3 into betacrypt cards
    Many thanks in advance
  5. #20
    Oct 2008
    Default Hypercam 1.0.4 multi receivers
    Hypercam 1.04 multi receivers
    Release 1.04
    => Added one type of *** card support
    => Added hypercam.status file, see configuration file for settings
    => Fixed clear => crypted switch for some channel not providing new PMT
    Thanks for Hypercam Devs for this piece of software !
    hypercam.1.04.7z
    Dreambox 7025-SS
  6. #21
    May 2009
    why in start of task there are this errors:
    cuberevo-250hd:/var/bin# start_hypercam.sh
    killall: mgcamd: no process killed
    killall: mg_launcher: no process killed
    killall: newcs: no process killed
    rmmod: sci: No such file or directory
    killall: hypercam.ipbox: no process killed
    /var/bin/api3-wrapper.sh: line 9: syntax error: "(" unexpected
    /var/bin/start_hypercam.sh: line 12: /var/bin/sci-ng.sh: not found
    Is non compatible with cuberevo 250hd?
    thank's
  7. #22
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    Quote Originally Posted by ipbox2008 View Post
    mgcamd is not running
    mgcamd_launcher is not running
    newcs is not running
    hypercam is not already running
    driver is probably already loaded and/or the .sh script files is missing from /var/bin
    only tested with 9000HD but dont see why that would stop working on 250HD
    thank's
    see RED.....
    boom!
  8. #23
    Oct 2008
    Default Hypercam 1.05
    Hypercam 1.05
    => Fixed clear => crypted switch / Dreambox PPC specific operations
    => Workaround for Dreambox PPC poor smartcard drivers timing...
    hypercam.1.05.7z
    Dreambox 7025-SS
  9. #24
    Oct 2008
    Default Cuberevo / mini Emulators
    Hypercam 1.0.6
    Hypercam 1.06
    Release 1.06
    => Fixed card support on Dreambox PPC for N2/N3/IRDETO/***
    => Fixed streaming decryption on Dreambox PPC
    Dreambox 7025-SS
  10. #25
    V.I.P. Member despdan's Avatar
    Midlands Ireland
    Quote Originally Posted by grizzlyt View Post
    Hypercam 1.06
    Release 1.06
    If we ever get a card dumped will this clear the channels on Irish n2 stream on a dreambox?
  11. #26
    Jun 2008
    Never Never Land
    @dan yes it will
    boom!
  12. #27
    Jun 2009
    thank you.
    did it work on qbox_hd also?
  13. #28
    Jun 2009
    hello.
    on my qbox run newcs well.
    another receiver like dream or dbox can connect to my box also well.
    but myself cannot connect to newcs.
    not incubus or hypercam.
    what make i wrong?
    in incubus conf i activated newcamd line.
    can anybody help me?
    thx
  14. #29
    aftermath's Avatar
    Mar 2008
    Default IncubusCamd 0.85
    IncubusCamd 0.85
    18/06/2009, V0.85
    - deleted old priority system for caid, now will be used firstly the prio and then a cycle selection
    - SID in hex value instead of dec one
    - fixed some bugs on caid ecm parsing
    - fixes for stability/less-crashes (crashes were made by the pmt handling, using pmt file wich the writes is slower than the channel change,
    now should be fixed in almost all cases)
    - still open the 2.1.1 protocol support and previous version
    - fixed a bug on reading keys for the internal emulator, now also unsupported softcam.key files are skipped in the unknown fields
    (read the softcam.key file to see how to build a new one)
  15. #30
    Jun 2009
    hi.
    i have incubus,but i will use my softcam.key for digitv.
    what should i do?
    i have write follow lines into the conf
    [Prov:002111:CaID:0000]
    decoder_type=0
    but the didn?t work.
    whats wrong?
    thx
