Cuberevo / mini Emulators
Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    aftermath's Avatar
    Mar 2008
    Default Cuberevo / mini Emulators
    IncubusCamd 0.7
    07/02/2009, V0.70
    - added auto-reconnection on servers (if lost connection previously)
    - fixed a bug that caused the lost of cws
    - added multi-server support for cccam (you can connect as a client to more than one server, this is a beta try, seems almost stable but it could have many bugs)
    - fixed nagra providers (nagra3 and nagra2) interpretation (now they should work on cccam protocol, but i've not tested it so please report if you find bugs)
    - fixed biss over cccam protocol
    - added possibility to get emu shared data by server on cccam protocol (see config file)
    - added logs information from console and into file (see config file)
    - changed a bit the config file
    Consider this version as a BETA one
    download from here
    download this "pack.tar.gz" and put into /tmp , and install from NLB panel.
    # incubusCamd configuration file                                             #
    # All configuration options in this file observe the same format:            #
    #     <configuration_name>=<configuration_value>                             #
    # Each section are [<section_name>:<option_1>:<option_x>] like.              #
    # No matter about white spaces on any place or UNIX/DOS style files          #
    ########################### general configuration ############################
    [General]
    # Enable (1) or disable (0) background execution
    # 0 - Off
    # 1 - On
    background_execution=1
    # This sets the level of console output for debugging:
    # 0 - No debug messages, 1 - First level debug messages, 2 - Second level debug messages,
    # 3 - Print all debug messages
    debug_level=3
    # This option enables (1) or disables (0) the writing of debug information to the
    # console.
    log_to_console=1
    # This option enables (1) or disables (0) the writing of console output to a log file
    log_to_file=0
    # When log_to_file is set to 1, this is the path and filename to write console
    # ouput to.
    logfile_name=/var/bin/camd.log
    # Used to activate on-screen messages. Username and password required if
    # HTTP authentication is enabled on enigma.
    on_screen_messages_show=1
    on_screen_messages_username=root
    on_screen_messages_password=
    on_screen_messages_key_update=1
    on_screen_messages_wait_for_key_update=0
    on_screen_messages_ecm=0
    on_screen_messages_emm=0
    #When activated, camd will listen on the specified port for connections. All
    #log activity will be broadcast in real-time to connected clients.
    console_logs_broadcast=1
    console_logs_broadcast_port=666
    ############################ caid configuration ##############################
    # First of all the cam use the incubusCamd.prio file, then use the
    # configuration below.
    # Sections are defined by the value of the CaID.
    # You can choose the default ecm table used by the codify, this means that
    # you can choose the first byte of the raw ecm that is downloaded from sat.
    # If you don't know what value to insert, use "80". (all value are in hex)
    # Default value for ecm_table is 0x80.
    # The option "priority" tells if one caid should be selected before try
    # another one with a priority value greater.
    # The less is the value the greatest is the priority. Choose from "0" to any value,
    # priority value is decimal.
    [CaID:0100]
    ecm_table=80
    priority=1
    [CaID:0500]
    ecm_table=80
    priority=1
    [CaID:0600]
    ecm_table=80
    priority=1
    [CaID:0919]
    ecm_table=80
    priority=1
    [CaID:093B]
    ecm_table=80
    priority=1
    [CaID:0B00]
    ecm_table=80
    priority=1
    [CaID:0D00]
    ecm_table=80
    priority=1
    [CaID:1700]
    ecm_table=80
    priority=1
    [CaID:1800]
    ecm_table=80
    priority=1
    [CaID:2600]
    ecm_table=80
    priority=1
    ########################### provider configuration ###########################
    # All parameters are in hexadecimal notation.
    # Each section is defined by the provider id value.
    # If you don't know the provider id value then use the provider id "000000" and ca id "0000".
    # On provider 000000 caid 0000 goes all provider wich are not declared. If the provider
    # is declared then the cam will use the provider founded.
    [Prov:000501:CaID:1833]
    # URL of card-server to use, formats are as follows:
    # newcamd://<username>:<password>@<hostname>:<port>/<des_key>
    # aroureos://@<hostname>:<port>
    # radegast://@<hostname>:<port>
    # Example:
    # newcamd://foo:bar@192.168.0.100:12345/0CE3476FF2E1C9D9A0A109B371E3
    # Multiple card-server url's can be specified for server fail-over.
    # If the emu fails to connect or fails to get valid CW's, it will try to
    # connect to other servers in a round-robin fashion.
    # Up to 16 servers can be added from index 0 to 15.
    # You can choose also to select a cccam or gbox server, but they must be declared
    # in the "servers configuration" section ( [Servers] ).
    # e.g. : if you want to use a cccam server for a provider you must put it on
    # the parameter card_server_url_0=cccam://
    # NO MATTER the value after the double slash because server configuration is
    # made in the section [Servers].
    # Only for newcamd, radegast and aroureos is usefull to put correct connection
    # parameters because they are provider dependent.
    # Example i want to use mine card into the slot with newcs for prov 0501 on nagra3 (caid 1833)
    card_server_url_0=newcamd://username:password@192.168.0.100:10550/0102030405060708091011121314
    [Prov:000101:CaID:1810]
    # newcamd://<username>:<password>@<hostname>:<port>/<des_key>/[EMM]
    # aroureos://@<hostname>:<port>/[EMM]
    # radegast://@<hostname>:<port>/[EMM]
    card_server_url_0=newcamd://username:password@192.168.0.100:10550/0102030405060708091011121314/EMM
    card_server_url_1=newcamd://username:password@192.168.0.101:10551/0102030405060708091011121314/EMM
    card_server_url_2=newcamd://username:password@192.168.0.102:10552/0102030405060708091011121314/EMM
    [Prov:000000:CaID:0000]
    # this provider is a stand-in for all cards and all caid not declared previously
    # For example I choose to use cccam protocol on all other provider.
    ########################### servers configuration ############################
    [Servers]
    # This is the section for the multi-server configuration.
    # cccam://<username>:<password>@<hostname>:<port>/<receive_emu_shared>/[EMM]
    # where <receive_emu_shared> should assume value "yes" (without quotes, if you like to receive emus data shared by the server) or "no" (this is assumed by default)
    # gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>/[EMM]
    # NOTE: The "EMM" suffix is optional and tells the card-server client whether
    # to send EMM's to the card-server or not. Enabling or disabling this only
    # has effect if the card-server is configured to accept emms from this client.
    # NOTE 2: The "card_server_url" is not the same as previously declared in the prov/caid section
    # use how many server as you like
    card_server_url=cccam://<username>:<password>@<hostname>:<port>
    aftermath's Avatar
    Mar 2008
    Default IncubusCamd 0.75
    Incubuscamd v.0.75 released
    12/03/1956, V0.75
    - fixed auto-reconnection on servers
    - fixed multi-server connections
    - fixed many bugs on memory that caused cam's crashes
    - fixed timeshift
    - fixed audio change selection wich cause the stop of video/audio on original dgs firmware
    GBOX protocol still not fully supported
    RapidShare: Easy Filehosting
    aftermath's Avatar
    Mar 2008
    Default IncubusCamd ver 0.8
    incubusCamd, cam daemon.v 0.80
    Available for processor types: sh4 (tested only on Cuberevo family receivers)
    Use the e2 version on cuberevo with enigma 2 on board, the other version (*.sh4) on ipbox 9000/900 with dgstation firmwares
    Use the sigma version on azbox hd firmwares
    Card client for protocols: cccam, gbox, newcamd 5.20, newcamd 5.25, radegast old, radegast new, aroureos
    Emulators for: Seca 1, Seca 2, Viaccess 1, Viaccess 2, Viaccess 2.3, Viaccess 2.4, Conax, Cryptoworks, Tps Crypt 1, Tps Crypt 2, Tps Crypt 3, Biss, Constant CW
    .conf and .prio files can be inserted in the /var/bin directory, or in /etc, or in /var/keys
    SoftCam.Key must be inserted in the /var/keys directory
    History:
    24/10/1917, V0.80
    - added caids tunneling (check the config file to know how to set them, used for example with PremiereHD card on betacrypt)
    - fixed cryptoworks provider id recognition
    - gbox protocol multiserver added
    - newcamd fixes for multiserver
    - radegast fixes for multiserver
    - aroureos fixes for multiserver
    - added test version of internal emu (see config file to know how to enable it)
    download here
    Mar 2009
    Cheers mate that looks like the road i'm gonna go down
    I will let you know how i get on
    Mar 2009
    This is going from bad to worse
    Trying to install Flashtools/ USB Driver via the USB cable method and managing to get "USB Upgrade" display on stb but then it goes ERR 10 immediatley before i attempt to do anything
    Any ideas/workaround?
    Mar 2009
    All sorted loaded image via USB Stick and now have everything running like a dream.
    Thanks for the earlier help
    Mar 2009
    What image are you using?
    I had to load the NLB9047 image and then configured the config file with the above and it's been working perfect.
    Mar 2009
    Yeah you are right about the gap but just checked my config and there is no gap so my fault for originally posting that config with the gap.
    Mar 2009
    Quote Originally Posted by jellybee007 View Post
    Are you sure your cccam version is not higher then 2.09?
    Otherwise it doesn't work.
    I dont know who you are replying to but your quoting my post and i have no problem. As you will see in post #8.
    Member grizzlyt's Avatar
    Oct 2008
    Default IncubusCamd ver 0.8.2
    IncubusCamd version 0.82
    - second try fixing caids tunneling (with PremiereHD card on betacrypt, i can't test it so, i don't know if it works or not)
    - first try fixing caid 0603 (same as premierehd, i can't test it, please report if it works or not)
    - fixed long ecm bugs
    - full support for cccam 2.1.0 protocol
    - many minor fixes for stability (hope this version will be better than last one)
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
    aftermath's Avatar
    Mar 2008
    History:
    05/05/1821, V0.82
    KNOWN BUG: sometimes with the timeshift option enabled you can occur problems during standby or channel change,
    so you need to restart the cam
    24/10/1917, V0.80
    radegast, aroureos and newcamd multiserver is done by using the card_server_url_0 _1 _2 and so on (max 16 provider)
    declared in the provider configuration [Prov:XXXXXX:CaID:YYYY] section.
    newcamd, radegast and aroureos shouldn't be declared in the [Servers] section (if found there, they will be ignored).
    The [Servers] section is used to connect only gbox and cccam servers.
    12/03/1956, V0.75
    - fixed timeshift
    GBOX protocol still not fully supported (i can't test it but i think it shouldn't work in this version)
    07/02/2009, V0.70
    Consider this version as a BETA one, i don't think it's really stable as i can think.
    GBOX protocol is not fully supported in this version, I will fix it in the next release.
    04/01/2009, V0.55
    - fixed some little bugs on DGStations api interface
    - added multi descrambling support for DGStations HD original firmwares (PIP, timeshift, recording channels, second tuner support)
    - added version sigma to be used with AzBox HD
    I've been noticed about many peoples not able to view some channels, don't forget to edit your prio file. Editing that file will give you the ability to chose the right pid wich the cam should be select (if you will not edit it, the cam will use the first pid and then try to use other pids, but this will take much more time to be able to see something)
    20/06/2008, V0.50, First public release
    camd33 and camd35 is really much unstable so I think it's not yet ready for public,
    asap it will be ready i'll publish it
    This is the first release, you can't see any log on the console because
    I don't wanna people read infos that could put them on the strange way.
    However logs on console are really good to know if bugs are the cause of your problem or
    simply if you are so noob to not be able to configure it correctly.
    Read very well config files and don't say something you don't know.
    This is not a fully working cam, some functions are not implemented/enabled because they are not ready for public and
    I think people don't wanna functions that are working not really good as they expected!
    (also this version is a beta version, but i wanted to put some hopes on people that believe a cam is better than othern one,
    we have tested the cam on many decoders and we can say this cam is not bad at all also in beta and not full working mode )
    So for the first release I choose to public only client side of the cam.
    I want to thank raton_craquero for givin' me the possibility to know really a lot of things on how to use dvb_api and i have
    to admit that i really like his config file structure and his log functions, so i decided to use them with his agreement
    Thank you!
    Regards, the IncubusCrew!
    aftermath's Avatar
    Mar 2008
    Default Hypercam v 1.0.3 SH4 version
    | HYPERCAM on SH4 - ABCOM IP9000HD / Cuberevo Setup Instructions|
    INTRODUCTION
    Here is a brief note on installation process required on
    ABCOM IP9000 HD / CUBEREVO from DGS.
    For now, The hypercam version delivered is only compatible with
    firmwares based on DGS images ( including NLB images), and using sbox
    as GUI.
    Actually, it's only able to manage the 'Live' descrambling !
    Future releases will also support PIP / PVR descrambling.
    Hypercam has just been adapted to handle decryption operations on
    this firmware / drivers. In a 'near' futur, drivers could change on the
    receiver and results in hypercam no more decrypting or crashing.
    You've been warned !
    Also please note that this binary has IP9000 dedicated embedded settings,
    so it won't work on other SH4 based STB such as QBoX or others, nor IP9000
    under Enigma2 images.
    Now it's up to you to use or not hypercam. Enjoy it !
    SETUP INSTRUCTIONS
    For now, you have to use a very simple installer.
    1 - transfer files into /tmp on receiver
    2 - connect with telnet to cuberevo receiver
    3- go into /tmp directory ==> cd /tmp
    4 - Be sure the install script is executable
    if not ==> chmod 755 install
    5 - Execute installer
    ./install
    Confirm installation when prompted
    6 - It can be necessary to configure your own settings, by editing
    file /var/bin/hypercam.cfg
    7 - when ready, type :
    /var/bin/start_hypercam.sh
    All activity reportings are, by default, written in /tmp
    hypercam.peers State of connected peers
    hypercam.localcards List of cards detected in smartcard readers
    hypercam.cards List of all available cards (local & remote)
    hypercam.schemes List of available encryption schemes
    for current channel
    here
  13. #13
    Mar 2009
    Default IncubusCamd version 0.82 feedback
    it runs mutch better than 0.80 I have only testet i on ccamd server with incubuscamd but it runs faster and no so manny glitches and freezes, cool work hope a new image from NLB is on it's way :-)
    keep up the nice work, nice update
  14. #14
    May 2009
    that's great! you saved my life
  15. #15
    Oct 2008
    Default IncubusCamd ver 0.8.3
    Incubus 0.83
    History: 21/05/2009, V0.83
    * fixed caid tunneling for premierehd on betacrypt over cccam
    * fixed bug for caid 0603 over cccam
    * fixed tv vlandeeren bug over cccam
    * compatibility with cccam 2.1.1 In this version only pid selected from prio file will be used, otherwise only the first pid on pmt list will be selected
    Dreambox 7025-SS
