thanks friend,i have schematic .....
Try connetions other radio end other computer
Make sure your init sequence is correct and in your picture you don't have the WDT marked - are you earthing it?
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
This radio was in he walked by someone else without knowing that if there...... try on other pc and not worked...
Pin 25 (AWD) TMS470 connect to GND.
yes friend ..pin 25 to GND ..and not worked same error ... Dunker i connect AWR pin to GND and not worked...
You tested other Ford radio?
not have other radio ...
connected ok projected bad
You have loaded the TMS470R1VF288 project file and not just selected the processor from the drop down list?
I selected yes and still not working ..I will try again tomorrow. This is same my problem and not solved .. link http://www.digital-kaos.co.uk/forums...-errors-99614/
It can be a pain in the arse reading TMS470 in circuit inside a Ford radio. You can have problems for ages and start doubting yourself. Then, eventually, it just starts to work and stays working. It is very strange. When using J-Mem, I sometimes have to connect using J-Flash and then immediately disconnect before firing up J-Mem and then it works. Keep at it and you will get there. Maybe scope the connections to see if you have good waveforms (although, I have never had bad waveforms when I have struggled to connect).
solved friend i use other j link !!my j link is the problem ... thanks for help!!
