Results 16 to 30 of 32
  1. #16
    Jan 2018
    воронеж RUS
    exactly the same problem as in the end everything was solved? I tried all the options. in the window of programming, and record the chip says hardware error but everything is seen and read((
  2. #17
    Garage
    I also have problem with my ak500+-
    I cannot read mcu and no write nec and ir port dont work.
    Is someone have dumps for controlers on ak500?
    For mega32 and str710fz2t6 from working device?
    And if someone have pictures off boards so I can compare with my device I see many components are missing maybe there is problem.
    I try to install on win xp win 7 on diferent laptops and always same errors.
    I ask seller for some advice but get answer that I need to buy another device.
    He send me link for same device from him.
    But I dont need 2 not working device.
    And my cd with org software is broken so can some one attach working software with working smartkey and witch install all files that need foe smart key to start.
    This is picture from my device.
    I ask for firmware update from seller but he say that does not have update even on site he say that have.
    Thanx advance
  3. #18
    Mar 2013
    Imao sam isti problem s AK500+
    Nije radio sve dok ga ne instaliram na računalo s Intelovim procesorom. XP / SP3 / 32
    ne radi s AMD procesorom.
  4. #19
    Same problem here,
    smartkey.exe not running no matter what i try.
    installed on different pc and different os systems
    maybe someone share the ak500 v1.0 sw?
  5. #20
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by sepistar View Post
    Same problem here,
    Check your Inbox.
    <---- Coin of the Realm.
  6. #21
    Quote Originally Posted by droidwayne65 View Post
    Check your Inbox.
    Thanks but it does not working either.
    Same thing win 7 x64 and fresh xp sp2
    It just keep crashing
  7. #22
    Aug 2015
    North America
    By crashing you mean it doesn't start up or it closes when you try to use some function?
  8. #23
    It does not start at all,just windows specific sound.
  9. #24
    Aug 2015
    North America
    It installs with no issues nor error messages?
  10. #25
    Garage
    I found solution on another place.
    Today later afternoon I will try to uploud and post.
    I cannot make it work until I did not instal this version on vmware.
    With this solution everything work ok.
    its some problem with drivers.
    Also I read somewhere that work on win xp black edition.
    Greetings
  11. The Following 2 Users Say Thank You to tomo776 For This Useful Post:
    Louislesinge (26th June, 2019), sepistar (26th June, 2019)
  12. #26
    Quote Originally Posted by tomo776 View Post
    Greetings
    I'm waiting then.
    On xp black edition already installed,but not working.
  13. #27
    Anybody else has that vmware?
  14. #28
    Not needed anymore.
    In my case smartkey.exe it start only if installed on IDE hdd
    So ak500 run ok and ir features too.
  15. #29
    Aug 2015
    North America
    Not needed anymore.
    LOL! I guess it's true then. I read this elsewhere a while back but discounted and forgot it because HRT software have run on any machine I've used without problems.
  16. #30
    Garage
    Sorry for late replay here it is if someone need.
    Here it is on mega.
    Greetings
  17. The Following User Says Thank You to tomo776 For This Useful Post:
    sepistar (28th June, 2019)
