ITGATE TGC 220 not working
Results 1 to 2 of 2
    Mar 2014
    Default ITGATE TGC 220 not working
    hi
    I have problems with my tgc 220 cable
    since I flashed the "original" image TGS220_update the box doesn`t run properly. the current image is TGS220 nabilosat darksat II DM7000. tuning is not working, and it keeps shuting down when I try to search operaters in tuning service.
    I tried to flash back the "original" image, but Control Center says "the selected file is not used for your receiver. Please select the relevant file for your receiver: TGM220 != NOT SUPPORT
    I also tried several other images, but I keep receiving that info from above
    which firmware image will work?
    May 2008
    If i remember right TGC 200 software works on the TGC 220, Look in the itgate section To double check.
    Try here http://www.digital-kaos.co.uk/forums...-image-149695/
