Page 100 of 125 FirstFirst ... 50909596979899100101102103104105110 ... LastLast
Results 1,486 to 1,500 of 1871
  1. #1486
    Feb 2018
    thank you but it is asking for password
  2. #1487
    Feb 2018
    [QUOTE=hcip;3358889]
    Quote Originally Posted by JTMONEY1928505 View Post
    https://mega.nz/#F!MV5lXRaS!HuZEJPO1b2pKysxEM2Xw6w
    sorry ignore first link it didnt have encryption key
    Reset
    ok after flashing id code box and certification ecu with the rest dumps i have no key on power, after i initialized with my x100 pro i would have key on jus torogramming failed now with id code box and smart ecu rest dumps i have no on piwer from the start button and x100 pro when trying to program the key says failed, i still have the dash out if this car but i dont think that should be an issue as the instrument cluster is plugged in, i cant figure what i could be doing wrong the xtool should have virginized the eeprom dumps i would have thought
  3. #1488
    husseinish's Avatar
    Jan 2018
    maldives
    Toyota Wish Smart Key Lost. Please Help me to Program a new key
  4. #1489
    Jul 2018
    I have a n00b question,
    How do you guys getting the dump files? By de-soldering the EEPROM chip from the smart ECU or is there some programm that download the dump without removing the ECUs??
    Thanks for your help
  5. #1490
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by Friends4eva View Post
    need to pull out the Smart ECU to read the eeprom,
    You can read the eeprom by obdstar or Tango without removing it, but no option to write it back to SmartECU via OBD
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  6. The Following User Says Thank You to hcip For This Useful Post:
    Friends4eva (31st August, 2018)
  7. #1491
    Oct 2017
    i have 2012 toyota landcruiser.
    A locksmith before me reset the smart box 3 times..BUt didnt had the correct key.
    Now it arrived at my garage.
    Problem is now immo light next to clock is not blinking.
    switch is not getting on.
    i get the key data from smart box by tango.
    but its immobox need to be reset.
    PLease help how to reset the whole system.
    i am able to switch on from fusebox for scan purpose.
    its only showing dtc B2289
    i need to reset ,if anyone know please help.
    I attached the both files before and after adding keys.i also try cn5 to copy key1.
    Security light should blink which is seem to be dead.its becuase of smart key box or id key box..which one could be faulty.?
    Regards,
    Asif
  8. #1492
    Sep 2015
    i can reset the immo ox file and id code. but when you use tango it will say that the smart box file is reseted. you can add key but sync may be lost. post both files id code and smart box
  9. The Following User Says Thank You to raheem1983 For This Useful Post:
    Asifmehmmod1 (6th September, 2018)
  10. #1493
    Oct 2017
    i post both files...before add by tango and after tango.
    Regards,
    Asif
  11. #1494
    Aug 2016
    GB
    you need virgin pm me
  12. #1495
    Aug 2018
    Hello everyone. Anyone has VIRGIN dumps to Reflash first gen Toyotas and Honda prelude?
  13. #1496
    Aug 2018
    And thank you gwee for sharing
  14. #1497
    garagecfa's Avatar
    Aug 2016
    Default PLEASE HELP ME SMART KEY BOX TOYOTA HIGHLANDER 2017
    HI
    I HAVE TOYOTA Higlander 2017 TOUT PERDU ikey besoin de réinitialiser LE DOSSIER DE BOITE
    IMMO BOX ID 89990-0E081 VEUILLEZ M'AIDER
    CETTE TRÈS URGENCE
  15. #1498
    Sep 2015
    Botswana
    hie guys
    im looking for help to align these files for toyota vitz smartkey, car came without immobox after replacing immo box car turns on but does not release sterring lock
    thanx in advance
  16. #1499
    Jul 2018
    Quote Originally Posted by LEORNARD NKATA View Post
    hie guys
    thanx in advance
    In this situation, releasing steering lock via diag will help or it doesnot matter? anyone tried? TIA
  17. #1500
    Oct 2018
    Please I need help master aketokediag, master gwee, master siham and all other DK masters
    I have a 2016 Rav4 all smart keys lost.
    It doesn't have ID code box.
    Smart ecu part number: 89990-0R040
    Please I need a virgin dump for the smart box.
    Also the steering lock has its information tempered with, can I get a virgin dump for it also.
    Can Techstream be used on the car after writing virgin dump on the smart ecu
    Thank you all in advance
    I really appreciate
