Page 85 of 125 FirstFirst ... 3575808182838485868788899095 ... LastLast
Results 1,261 to 1,275 of 1871
  1. #1261
    Mar 2017
    hello guys any one can help me with reset file hilux 2.5 2010 g chip? thank u
  2. #1262
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by huga46 View Post
    Post your dump here. Can reset
    Sent from my F3216 using Tapatalk
  3. The Following User Says Thank You to Brayn For This Useful Post:
    LooserX (25th May, 2017)
  4. #1263
    Apr 2017
    Hello francs any body side haw ajadoogare bin editor
    Sent from my HUAWEI VNS-L31 using Tapatalk
  5. #1264
    Hello dear members i want to ask about wiring diagram of smart key system for toyota landcruiser 2016 diesel engine vdj200 thanks for any help
  6. #1265
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by Saman View Post
    What is your problem mate??
  7. The Following User Says Thank You to Brayn For This Useful Post:
  8. #1266
    Nov 2012
    HI FRIEND
    I need vrigin files for toyota prius 2010 all keys lost
    smrt key ecu 89990-47050
    Thanks!
  9. #1267
    Oct 2015
    here u go mate..... pass in p.m after press thanks and rep.
    No Thanks, No Report = No HELP
  10. The Following 4 Users Say Thank You to usman4 For This Useful Post:
    abvayani (22nd May, 2017), bermuxa77 (20th May, 2017), Brayn (20th May, 2017), LooserX (25th May, 2017)
  11. #1268
    Dec 2013
    Africa
    HI Mates
    i have Toyota BB likeToyota passo.
    i done programe 4c Transponder via Tango but car not recognise transponder what should be a Issue. i have to use a Virgin Dump ?
    i already try with CN2 Transponder via Tango still not starting.
    if any body know this issue let me know
  12. #1269
    Apr 2017
    Waits eprome chip 93c56 or 66
  13. #1270
    Dec 2013
    Africa
    SOLVED CAR START
    Quote Originally Posted by abvayani View Post
    HI Mates
  14. #1271
    Hello I have a problem Car stops working and have a fault code B2786 No Response From Steering Lock ECU , I think Steering Lock is ok and have a problem in Smart key ECU but for checking I need wiring diagram thank you for any help.
  15. #1272
    Dec 2013
    Africa
    have you chq a ST Lock Fuse in fuse box that the 15AP Fuse
  16. #1273
    Yes I cheked the fuse inside the steering lock there is 5v power supply and steering lock supply is ok i moved the magnetic part on the steering lock while i swich ignition on and the car can not start i need wiring diagram for smart key ecu
  17. #1274
    May 2017
    hello mate still you have problam? what is your vehicle and tell me some details. i can help you
  18. The Following User Says Thank You to LooserX For This Useful Post:
    Brayn (25th May, 2017)
  19. #1275
    Dec 2013
    Africa
    Toyota Mark X Esl and ID Code Wiring Diagram Required Please
    Chasis Number Grx120-3035913
