Page 87 of 125 FirstFirst ... 3777828384858687888990919297 ... LastLast
Results 1,291 to 1,305 of 1871
  1. #1291
    siyadk's Avatar
    Dec 2012
    Quote Originally Posted by duytrinhvn View Post
    No tool can program all key lost. you need buy new smart box+ steering lock replace
    not true....!!!
  2. #1292
    rob h's Avatar
    May 2011
    yaris 2015, smart key, page1=39
  3. #1293
    Mar 2016
    Quote Originally Posted by siyadk View Post
    not true....!!!
    YOU CAN TELL ME WHY NOT TRUE...
  4. #1294
    iamfooser's Avatar
    Sep 2012
    Because we can do it.
  5. The Following 2 Users Say Thank You to iamfooser For This Useful Post:
    bearheroes (18th June, 2017), siyadk (19th June, 2017)
  6. #1295
    Mar 2016
    Quote Originally Posted by iamfooser View Post
    YOU CAN TELL THE TOOL CAN DO IT ? I NEED BUY IT
  7. #1296
    siyadk's Avatar
    Dec 2012
    because you need more than tools like experience and brain.exe... and some of members like me are hesitant to share the info to a newbie who has less contribution history in DK. I suggest you start building your reputation here and stop using CAPS
  8. #1297
    Apr 2014
    Thank You Mate...
  9. #1298
    Apr 2014
    Thank You Mate !!
  10. #1299
    Apr 2017
    Hello, which car you wanna do all key lost?
  11. #1300
    Dec 2013
    Africa
    problem solved ?
    Quote Originally Posted by chichomeyer View Post
    Hi guys, need help with this toyota allion with smart key system. All keys lost and can't get to reset ECU through OBD2, tried using obdstar x100 pro, t300, and techstream with no luck. So removed the dash and got out the immo ecu and smart key ecu, read both files and attached them here. If I get the dump reset and loaded back, will I be able to code a new key by obd2?
  12. #1301
    Sep 2015
    myanmar
    Quote Originally Posted by UliZam View Post
    hello friend
    post your ID Box
    Smart Box Reset here, pass inbox
    try and report please...
    HELLO FRI, please help me pass for 93c86 smart box and id box reset file. pass please
  13. #1302
    Apr 2014
    Quote Originally Posted by sadarmeng View Post
    Dear DK member
    Please help me to add new key to smartkey yaris 2015
    Key Attachment 454208. Situation is all key lost.
    thank you
    Problem SOLVE... Thank You DK member...
  14. #1303
    May 2012
    HI! I have 2013 Lexus is250 all key lost, I have NEW one smart key and I take off certification ECU and ID-BOX ECU and read eeprom. Please HELP reset certification ECU and ID-BOX ECU for programming smart key over Toyota Teachstream. PS That is model have steering lock ecu, so I need read dump from steering lock ECU? Thank YOU!
    Certification ecu 93c86.rarid box 93c46.rar
  15. #1304
    Apr 2014
    Quote Originally Posted by Adamon777 View Post
    I think your data is virgin pack, no key is detected, put in eeprom, register all keys, then sync idbox and steering lock, use techstream, and lastly connect obd pin 4-13 for 30 minutes more. As it is possible, please correct me if i am wrong
  16. The Following User Says Thank You to sadarmeng For This Useful Post:
    kyawkyaw (10th December, 2017)
  17. #1305
    Jun 2017
    Can anybody help me virginize this Toyota Matrix 2006 dump? I lost all my keys.
    It is from the 89780-02060 immo unit. The eeprom is a 93c66.
    Thanks in advance!
