Page 93 of 125 FirstFirst ... 43838889909192939495969798103 ... LastLast
Results 1,381 to 1,395 of 1871
  1. #1381
    ibratex's Avatar
    Jul 2015
    angola
    any hand for help mates please kindly
  2. #1382
    Nov 2016
    Post ECU file too
    Enviado desde mi iPhone utilizando Tapatalk
  3. #1383
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    Quote Originally Posted by ibratex View Post
    those smart dump aren't the same. The one which has more data is for pg1 98 while the other with less data is for pg1 94.
    what year is the Lexus? if 2008+ most probably is pg1 98 i believe.
  4. The Following User Says Thank You to ucokseparoh For This Useful Post:
    ibratex (18th December, 2017)
  5. #1384
    Sep 2015
    hi IBRATEX... i checked your files. the working files for your car are uploaded. no need to load file from ecu. just use this files. add one smart key and thats all. if the car fails to start just jump reset your car ecu. this files have working synchro code
  6. The Following 2 Users Say Thank You to raheem1983 For This Useful Post:
    checkservic (5th July, 2023), ibratex (18th December, 2017)
  7. #1385
    ibratex's Avatar
    Jul 2015
    angola
    thanks brothers , i already had a read for ecu file i will post it now in case we need after i try your files ,,,, thank you so much i will report
  8. #1386
    Sep 2015
    THE FILES I SENT YOU AND THIS ECU FILE ARE NOT SYNCHRONIZED. YOU WILL NEED TO MAKE ECU RESET BY JUMPER.
  9. #1387
    autodigitec's Avatar
    Aug 2011
    PT
    can someone reset my immobox? However not sure what I have to do after it is reset.
    Do I just need to cycle the key in ignition or code it with Techstream/Intelligent Tester?
    Sync with ECU in the OBD2 pins is done after adding key or before?
    (Sorry for so many questions, I'm kinda new to toyota immo system.)
    Working on something to release next month for free for all dk users :>
  10. #1388
    May 2016
    Default Toyota Yaris all key lost need help
    Hi all members,
    Can anyone please help me add smart key or reset smart box for 2014 Toyota Yaris (ThaiLand) lost all keys. I have read the smart box with 93c86 eeprom and Steering lock with 93c46 eeprom. I have 2 keys (1 used key and 1 new key). All the files and images in the attachment.
    Thank in advance
  11. #1389
    Nov 2015
    South East Asia
    Hi members,
    I need some help with this vehicls.
    I have a Toyota Hiace Mini Bus.
    Smart box 89990-26021, 93c86
    ID code box 89784-26010, 93c46
    Not given steering lock. For some reason owner doesn't want to pass me.
    Both I have read the dump.
    Q1) Can I make keys with just the 2 virginised dumps, without the steering lock dump?
    Q2) How to virginise the dump?
    Thank you so much for your advice!
    I will post my files later as they are not with me now.
    Oeyek
    Sent from my SM-G935F using Tapatalk
  12. #1390
    Nov 2016
    Hello friend
    Post here and I will make virgin the dump for you
  13. The Following User Says Thank You to UliZam For This Useful Post:
    oeyek (9th January, 2018)
  14. #1391
    Nov 2015
    South East Asia
    Hi my friend
    The files are attached here thank for your help @ Ulizam
    Thanks a million
  15. #1392
    Nov 2015
    South East Asia
    Quote Originally Posted by oeyek View Post
    Hi my friend
    Thanks a million
    Hi guys
    Any kind souls there to help with the reset/virginisation of this ID code and smart box IC data?
    Appreciate your help.
    Running out of time here.
    Cheers
    Oeyek
  16. #1393
    Nov 2016
    Hi my friend
    Thanks a million
    Hello friend
    sorry for delay
    tell me this file is smart key unit and ID ECU unit?
  17. The Following User Says Thank You to UliZam For This Useful Post:
    oeyek (10th January, 2018)
  18. #1394
    Nov 2015
    South East Asia
    Quote Originally Posted by UliZam View Post
    Hello friend
    sorry for delay
    yes sir, thanks for the reply
    93c86 is smart key unit
    and
    93c46 is ID ECU unit
    Thank you.
  19. #1395
    I have Toyota Land Cruiser 2007 lost all smart keys,
    this model comes from the Gulf State (UAE)
    i try reset via obd not possible, here i attached smart key unit and id code box,
    any help will be appreciated,
    Regards.
