Page 99 of 125 FirstFirst ... 4989949596979899100101102103104109 ... LastLast
Results 1,471 to 1,485 of 1871
  1. #1471
    Aug 2016
    GB
    hi this your virgin , do not forget rep n thanks
  2. The Following 2 Users Say Thank You to autocar88 For This Useful Post:
    damih (16th July, 2018), urcarpc (10th April, 2023)
  3. #1472
    Plcautoparts's Avatar
    Mar 2013
    Hello
    I have a 2006 Lexus GS300 with code B2799, which tells me the immobilizer is bad. What is the proper way to fix it? Could I use a used immo, or has to be new? And what is the best tool to use in order to get this car going?
    Thanks in advance.
    Sent from my SM-G955U using Tapatalk
    A simple thanks would do, If it didn't work at least I tried.
  4. #1473
    Default 2010 TOYOTA LANDCRUISER PRADO
    Hello Mate,
    Please need help in adding the following Smart key data in the dump attached
    Page 1: 98
    Page 2: 71
    Page 3: 2F 73 6E 1C
    Page 6: 2F 73 6E 1C 71
    Page 7: 00 00 00 00 00
    Page 8: 98 30 A0 27 27
    Page 9: 98 A0 82 00 04
    Best Regards
  5. #1474
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Try this.............
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  6. The Following 3 Users Say Thank You to hcip For This Useful Post:
    alektkac (5th December, 2019), lock66 (1st October, 2018), ngakson2002 (13th August, 2018)
  7. #1475
    marco70's Avatar
    May 2012
    Lawok
    Hi all.
    Please reset smartkey idcodebox.
    Yaris 2005r EU.
  8. #1476
    Aug 2010
    hi guys,
    Can someone please reset this smartkey ecu so i can add keys after all keys lost?
    Thanks!
  9. #1477
    Feb 2018
    i am new to this forum but maybe i can be some help to some of you, but as it is i have a huge problem with a 2010 lexus is250. all keys lost took to dealer they said all modules need to be replaced so we didnt pay brought the car home and the acc wouldnt turn on. removed certification ecu and id code box and virginized both eeproms woth x100 pro. when i try to get it to program my used key it says failed, i have tried everyrhing that i can think of, is it my old key?? i troed code reset with techstream, it fails within 1 minute after entering the passcode, i bought another id code box and certification ecu from ebay because the dealer said my ecus were locked due to too many key program attempts now i am stuck and i have no direction to go, if someone could shed any light on my situation i will be grateful, thanks JT
  10. #1478
    Feb 2018
    sorry forgot to mention that after initializing data with x100pro the acc or igntion will now turn on and i still have the dash out of the car because i want to make sure that the key is programmed where it will start before i put it back together so i have the instrument cluster plugged in and techstream warns me to make sure smart key cancel switch is not turned off but i dont think this car has one
  11. #1479
    Aug 2016
    GB
    Post smartkey ecu dump
  12. #1480
    Feb 2018
    i will post as soon as i get home, i went ahead and ordered a new key from amazon because there were mixed answers about whether the used key woul work or not and abrites says key on is250 cant be reused so i bought another one waiting on it to come in was gonna try it
  13. #1481
    Feb 2018
    couldnt add the files to my message so i am posting mega link will both id code box and smart ecu dumps
    https://mega.nz/#F!MV5lXRaS
  14. #1482
    Feb 2018
    https://mega.nz/#F!MV5lXRaS!HuZEJPO1b2pKysxEM2Xw6w
    sorry ignore first link it didnt have encryption key
  15. #1483
    hcip's Avatar
    [QUOTE=JTMONEY1928505;3358349]https://mega.nz/#F!MV5lXRaS!HuZEJPO1b2pKysxEM2Xw6w
    Reset
  16. The Following 3 Users Say Thank You to hcip For This Useful Post:
    clauberty (18th May, 2019), JTMONEY1928505 (29th August, 2018), macvernal (24th February, 2019)
  17. #1484
    Feb 2018
    could you send the file to me with a mega link because it just shows attached files but there isnt anything for me to click and i think its because i havent long joined the forum so i guess i cant download any links yet
  18. #1485
    Aug 2016
    GB
  19. The Following User Says Thank You to autocar88 For This Useful Post:
