Page 102 of 125 FirstFirst ... 25292979899100101102103104105106107112 ... LastLast
Results 1,516 to 1,530 of 1871
  1. #1516
    Oct 2018
    hi guys,
    Can someone please reset this smart key ecu and ECU ID CODE so i can add keys after all keys lost?
    Toyota Aqua 2013 push start
    Thanks!
  2. #1517
    Oct 2018
    Please can you send me password
    Regard
  3. #1518
    Sep 2017
    Default ***Toyota Smart Lost Key Solution - No Id code needed***
    Quote Originally Posted by marco70 View Post
    Hi all.
    Please reset smart box or STEERING LOCK ( no idcodebox this model)
    89990-08010 smart box 93C86
    45020-02290 steering lock 93C46
    Thanks.
    Hi Marco70
    Did you fix your 2015 Sienna smartkey? I have one 2016 Toyota Sienna that I can't get it to start
    Original smart box is a brick now
    I Got me a used one from junk yard , I programmed 1 key (same key came with vehicle) thru eeprom 93c86 . I can open dash and got ignition touching the push-start button only , no lock/unlocked remote, no prox , don't work. I sync'ed 45 mins short obdii 4-13 pins before tried to start
    Vehicle Cranks but no start , immo light goes out , but I can't program more keys , i got no access to any module thru obdii not even Main ECU under wood , key scanners quit working adding a key halfway its process. Can you help me.
    Thank you
    * One thing I have noticed is the steering wheel never gets locked ign on or ign off
  4. #1519
    garagecfa's Avatar
    Aug 2016
    Quote Originally Posted by lion0304 View Post
    Here your Reset file, use master 36 or 56.
    See my signature for PSW in PM.
    hi mate please send the file
  5. #1520
    Oct 2015
    Toyota prius V 2012 need virgin id code ecu
    ecu toyota 89784-47020
    eeprom S93c46
  6. The Following User Says Thank You to alfredd For This Useful Post:
    mario.ie (22nd October, 2019)
  7. #1521
    Jan 2012
    Quote Originally Posted by alfredd View Post
    eeprom S93c46
    Here is vigin . Pass in pm .
    Best Regards
  8. The Following 2 Users Say Thank You to Niaz For This Useful Post:
    alfredd (20th December, 2018), antonypaul (21st March, 2024)
  9. #1522
    Apr 2014
    Hi guys please add key to dump.
    P1- 9F
    P2- 46
    P3- DA1A5F1A
    P8- 9F306C4646
  10. #1523
    Dec 2018
    Yemen , Aden city
    Urgent prado 2012 any one can reset those files
    I have work it for 2 day with out any spark of hope
    Whene i do jumer for DLC. Show me 99
    Engin run and stop every time i bush th button
    I well be greetful for help
    If any one can add the new key then he must
    Need
    P1:98
    P2:66
    P3: DC CB 61 1D
    Thank U advanced
  11. #1524
    Mar 2016
    Hi mates , 2007 previa with smart key, problem is that there is no crank , i can make ignition on/off ,green light ok when brake, tried to synronize ecu by diagnostic and by jumping pins 5 and 13 but same problem , i reached the smart key box and the st lock box but didnt reach an id box which made me confused , is this car have a stolen id box or it make work without id box ??
  12. #1525
    Oct 2015
    Default Please reset smart & id code
    Please reset smart & id code,
    Prius V 2012
    I have one original key.
    Engine in motion stopped working
    After that, it started up and stopped after a few seconds.
    In Power manegment ECU - B2799
    I reset ID CODE ecu & after ECU code registration & ECU communication ID regestration lamp immo - blinking and not READY
    Ignition - on
    remote- working
    The key has become defined as Master
    I also have eeprom TC after, and eeprom PMC before and after all the action.
    I don `t know what to do next. I think that the eprom is damaged
    THX
  13. #1526
    Dec 2018
    Default Immo off 0r reset Daihatsu Mira 2011
    Please help to reset Daihatsu Mira 2011 immo . immo box Tokai Rika 89990-B2470 chip 93LC66B.
    and transponder type 4C or 4d?
    Tanks
  14. #1527
    wembleyhill's Avatar
    Feb 2009
    Hi all i virgin file smart key 89990-45080 and transmission control 89535-75010 for prius 2013 all keys lost jap import
  15. #1528
    Feb 2009
    hi can someone please help me to start this car with used key
  16. #1529
    Apr 2014
    Quote Originally Posted by wembleyhill View Post
    Is this a new smart key system where the transmission control is part of the immo?
    Sent from my SM-G930F using Tapatalk
  17. #1530
    Feb 2009
    Quote Originally Posted by trinicolin View Post
    hi yes from what i've read so far i think it is can you help me with this ?
