Page 11 of 125 FirstFirst ... 6789101112131415162161111 ... LastLast
Results 151 to 165 of 1871
  1. #151
    cjawahir's Avatar
    T&T
    Quote Originally Posted by abvayani View Post
    Hi Gwee
    I have a problem with Toyota Rush. Its a keyless remote.
    Remote lock & unlock is Working fine but the car dosnt start. And remote light blinking a green colour.
    It must be a red light ?
    And when remote inside the the stil security light is blinking.
    Toyota Ractis remote like Passo remote.
    What you sagguest about this prblem
    you can use the mechanical key insert in ignition and use the remote keep near the ignition switch and try to start .
    the remote can read as a 4c chip .
    cj
  2. The Following 2 Users Say Thank You to cjawahir For This Useful Post:
    gwee (31st July, 2014), kyawkyaw (28th July, 2017)
  3. #152
    Dec 2013
    Africa
    Ok ill try and let you now
  4. #153
    Dec 2013
    Africa
  5. #154
    Dec 2013
    Africa
    Its a smart key for toyota Rush.
    Cjawahir
    Hi if i follow your procesure tommorow morning. ill give a update tommorow
  6. #155
    cjawahir's Avatar
    T&T
    hello , here is a pic to follow ,its not the best drawing but u have the idea .
    cj
  7. The Following User Says Thank You to cjawahir For This Useful Post:
    abvayani (31st July, 2014)
  8. #156
    Dec 2013
    Africa
    I try to read a transponder via CN900. But there is NO TRANSPONDER FOUND . i think customer lost his transpoder bcoz he change the bettery of remote after that its not working
  9. #157
    Dec 2013
    Africa
    Ok ill do it. Then get back to u
  10. #158
    Mar 2011
    Default Lexus
    Hello MR GWEE, can you please add this smart key to the dump for lexus, king regards.
  11. #159
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by fadhle View Post
    Master Qwee is out painting the town Red ... this should work though .
  12. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    cjawahir (3rd August, 2014), fadhle (4th August, 2014), gwee (4th August, 2014)
  13. #160
    Mar 2011
    Thank you premierD.
    Quote Originally Posted by PremierD View Post
  14. #161
    Dec 2013
    Africa
    Hi, Bro
    you Guys are Rocks.
    ill open the remote then ill read via CN its working.T
    Thank you Soo much .
  15. #162
    Mar 2011
    Thank you Mr Tyrone job done, king regards.
  16. #163
    HELLO GWE CAN YOU HELP ME WITH RESET OF THIS TOYOTA AURIS?
    THKS IN ADVANCE
  17. #164
    ITS ME AGAIN Mr. GWE WITH ONETHER TOYOTA ITS A 2005 VITZ
    HERE IS THE DUMP
  18. #165
    Dec 2013
    Africa
    Hi Gwee
    I try to make a Duplicate remote. I remove 93c46 dump and past another IC.
    Now both remote showing red light .both of them not working.
    What would be the issue.
    Can you suggest me what will i do ?
    Thanks in Advance
