HELLO MASTERS I GOT ANOTHER AURIS SMART KEY
CAN YOU RESET IT FOR ME?
Hello dear sirs masters of toyota, can you give some help for beginners, please can you add this smart key brand new dealer to dump:
pg1: 98
pg2: 09
pg3: 761EB81D
pg8: 98242D487B
THANKSSSSSS
HI friend i have TOYOTA land cruiser 2012 lost all key
smart key box 89990-60144
can add this key please
key data
P1 98
P2 83
P3 6B 38 19 2A
P8 98 24 11 FA E4
key added:
SO THANK bram380 BUT CAR NOT START AND NO REMOTE
THIS NEW KEY FROM DEALER
KEY DATA
P1 98
P2 F8
P3 53 18 30 1D
P8 98 2B 14 CF 57
New & used smartkey different algo in smart ecu.
So important to know new or used key will be add.
Hello masters, I go to the car started ok but remote proximity fuction isn't working, I reprogrammed the key but no succes reprogramming, and still no working Remote proximity Fuction the key is supposed to be new brand from the dealer, i have all the packages from the key and invoice in my hands, wich is the correct procedure after recieving the dump from mr. Gwee to get proximity working?
thanks for helping me
sooooooo thank gwee car start 100000000000000% start and remote WORK all smart funcation work perfect and i add anather key by X-100
soory bram my first key is used mistake by me i was think new
Hello again.
I've already saw you post telling me it's used key but i need to be sure if i'm doing well the reprogramming Procedure with techstream, and then go to the dealer and complain about the used key.... can some one explain me wich is the correct way of reprogramming the same key to get proximity working? This is the way I'm trying:
1. go to Entry and Start
2. go to utility
3. register key code
4. Touch button sw with REGISTERED KEY.....ok
5. Touch button sw with "KEY TO BE REGISTERED" #Here i get stuck# the time gets over and nothing happens!!
Am i Doing something wrong?? If key is totally virgin the same key will get over the 5 step??? many thanks
help me please
F***ing dealerrs... definetly key is used... thanks mr. Gwee for all the support you have given to me!! As soon as I get Another key i will post here!! much much tanks for your help
Hello the car has the steering wheel in LEFT side, the key frequency is 433 MHZ,
dear Gwee If the owner decides to reset both modules idcodebox and smart key ecu to use the "used key", ?? to start the car with techstream the procedure would be: "register ID of comunication ECU" of Just "Register key code"???
pd: please don't get mad with me it's the first smart key im programing and it's thanks to you
Hello Mr Gwee
i have land crusier 2010 all key lost want to make car running , car is 200km far from me so total 400 km , i hope you give me working key thanks
I've removed whole dash but still can't see it, where is it hidden? don't you have a pic of the location of id code box for Left hand drive Land Cruiser Prado?
