Page 91 of 125 FirstFirst ... 41818687888990919293949596101 ... LastLast
Results 1,351 to 1,365 of 1871
  1. #1351
    Mar 2017
    Kitwe, Zambia
    Hello I am quit knew to key programing and obd diadnosis/ ecu reset, but I have vast experience in odometre correction at eprom level. can some assist me on the right tool to buy that can cover a number of cars on key programming with eprom programing.
    Hello I am quit knew to key programing and obd diagnosis/ ecu reset, but I have vast experience in odometre correction at eprom level. can some assist me on the right tool to buy that can cover a number of cars on key programming with eprom programing. I need all knowledge I can lay my hands on .
    - How and where to locate immo chip
    - what type of keys i can use for different type of cars
    - how to programme transponder and keyless/ smart keys
    and many other information i may have not included. iam very good at electronics so that wont be a problem.
    contacts : whatsapp +260977615007, skype gerald.ngoma and email gtngoma@yahoo.co.uk
    regards Gerald
    regards Gerald
  2. #1352
    Oct 2017
    Toyota_smart.JPGThis is Key that I whant to add.
  3. #1353
    Oct 2017
    Hi Mates!
    Could you help me please with adding smart key to Alion 2007, Japan? Smart key ECU dump and key data attached.
  4. #1354
    Nov 2016
    Quote Originally Posted by Akvilon View Post
    Hi Mates!
    Friend
    Send both dump
    ID Box and Smart Key Box
    I will make reset for you
    Enviado desde mi iPhone utilizando Tapatalk
  5. #1355
    Oct 2017
    Quote Originally Posted by UliZam View Post
    Friend
    Send both dump
    Could you please add my key data to Smart key ecu dump?
  6. #1356
    Nov 2016
    I don’t friend sorry just reset
  7. #1357
    Oct 2017
    Anybody can add key to Smart box ECU without reseting ID and smart boxes?
  8. #1358
    DK Veteran viejomatius's Avatar
    Jun 2009
    Hello friends
    i need some orientation
    What to hope on a Land Cruiser 200 2016?
    will have eeprom on smart key ecu? could be added key by dump and after finish program by diagnostics?
    someone has had this experience and can tell me?
    thanks in advance
    Work Smarter Not Harder
  9. #1359
    Nov 2017
    Hi I'm looking for a virginized immobillizer dump for a jzs171 toyota crown 93C56 chip. Thanks in advance!
  10. #1360
    Oct 2017
    Default 4RUNNER 2013 SMART KEY
    Hi, working on this toyota 4runner 2013, smart key, all key lost, but seems likes somebody else works on this car before,
    I write a smart key with tango, remote work, ignition comes ON, but NOT START. steering lock doesn´t retrieve, light in the start button comes Green,,,,,,, BUT NO START.
    would anybody please check if i´m doing something wrong please?
    thanks in advance
  11. #1361
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by keysandmore2228 View Post
    thanks in advance
    if steering lock not release you have to virgin ID code box and program it then all will work well. now your problem is Steering lock and ID code box not matching
  12. The Following User Says Thank You to Brayn For This Useful Post:
    keysandmore2228 (17th November, 2017)
  13. #1362
    Nov 2016
    Default ***Toyota Smart Lost Key Solution - No Id code needed***
    thanks in advance
    Friend just need make virgin
    Try and Report later
    Press thanks and rep if I help you
  14. The Following User Says Thank You to UliZam For This Useful Post:
  15. #1363
    Oct 2017
    Default FILES FROM IC CODE BOX, AND ESL
    hi, friends, attached files from id code box, and steering lock, would somebody please modify this files
    thanks in advance for any help
  16. #1364
    Jan 2017
    Quote Originally Posted by mra999 View Post
    Toyota Corolla Smart Key Dump Attach 93c86 I need Reset to Register New Keys
    I try To Read Key Info By Tango And Zedbull And Zedfull Also Avdi But No Info Found
    So unable to Post Key info Hope will Work Your Dump to start car
    http://abdullahautos.ucoz.com/2016ca...VITZ_RESET.png
  17. The Following User Says Thank You to abdullah123 For This Useful Post:
    keysandmore2228 (21st November, 2017)
  18. #1365
    Jan 2017
  19. The Following User Says Thank You to abdullah123 For This Useful Post:
