Post ECU file too
Enviado desde mi iPhone utilizando Tapatalk
Post ECU file too
ibratex (18th December, 2017)
hi IBRATEX... i checked your files. the working files for your car are uploaded. no need to load file from ecu. just use this files. add one smart key and thats all. if the car fails to start just jump reset your car ecu. this files have working synchro code
checkservic (5th July, 2023), ibratex (18th December, 2017)
thanks brothers , i already had a read for ecu file i will post it now in case we need after i try your files ,,,, thank you so much i will report
THE FILES I SENT YOU AND THIS ECU FILE ARE NOT SYNCHRONIZED. YOU WILL NEED TO MAKE ECU RESET BY JUMPER.
can someone reset my immobox? However not sure what I have to do after it is reset.
Do I just need to cycle the key in ignition or code it with Techstream/Intelligent Tester?
Sync with ECU in the OBD2 pins is done after adding key or before?
(Sorry for so many questions, I'm kinda new to toyota immo system.)
Working on something to release next month for free for all dk users :>
Hi all members,
Can anyone please help me add smart key or reset smart box for 2014 Toyota Yaris (ThaiLand) lost all keys. I have read the smart box with 93c86 eeprom and Steering lock with 93c46 eeprom. I have 2 keys (1 used key and 1 new key). All the files and images in the attachment.
Thank in advance
Hi members,
I need some help with this vehicls.
I have a Toyota Hiace Mini Bus.
Smart box 89990-26021, 93c86
ID code box 89784-26010, 93c46
Not given steering lock. For some reason owner doesn't want to pass me.
Both I have read the dump.
Q1) Can I make keys with just the 2 virginised dumps, without the steering lock dump?
Q2) How to virginise the dump?
Thank you so much for your advice!
I will post my files later as they are not with me now.
Oeyek
Sent from my SM-G935F using Tapatalk
Hello friend
Post here and I will make virgin the dump for you
oeyek (9th January, 2018)
Hi my friend
The files are attached here thank for your help @ Ulizam
Thanks a million
oeyek (10th January, 2018)
Hello,
I have Toyota Land Cruiser 2007 lost all smart keys,
this model comes from the Gulf State (UAE)
i try reset via obd not possible, here i attached smart key unit and id code box,
any help will be appreciated,
Regards.
