keysandmore2228 (21st November, 2017), kyawkyaw (1st December, 2017)
autocar88 (26th November, 2017), EEpromchanger (22nd August, 2018), ibratex (12th December, 2017), keysandmore2228 (21st November, 2017), rewired (20th January, 2018)
hi, job done!!!. thanks for the help
I have an stolen and found back RAV4 Hybrid 2017 in my garage. Itīs all keys lost situation. This car has smartbox, id code box and esl. I already tried to reset smartbox (93C86) and ID code box (93C56), but without success. I believe I reset the ID-Box wrong way. And Iīm not sure, whether the key I have for this car is the right one. On sticker MR6903/2012 BA2EQ. Itīs keyless.
Can anyone of you reset my smartbox and id-code box?
Thank you very much in advance.
Greetings MR...
That key should be fine.
tms37200 page88
What tools do you have?
Tango could easily ad a key, direct to your smartbox.
Posting some partnumbers, should help solving this!
Unfortunetly I have no tango. I have VVDI2, VVDI Prog and Techstream. Normally VVDI2 should do this job also, but my unit does not recognize this kind of keys. And my smartbox dump is unknown version for VVDI key tool. So resetting the ID box should be the best way for me. I can reset the Id Box with 93c46. But the id box with 93c56 is my first one. I tried to reset it with FVDI toyota, but I believe it deletes to much. The system detects 0 keys, so I have to touch with key I want to register, but no beep and error message in techstream. I tried to set only keycount in id box to 0, but with same result. No beep at all. With unmodified id box, system of course asks for master key. When I touch with key for car I hear one beep. So I think hardware of car is good. Only reset of id box is wrong. The reset of smart box is the same as all with 93C86. I‘m sure, I did it the right way. Because of situation of this car, it was stolen and found back by police, I cant be sure, whether the smart box and key is original from car. So I also virginized the smart box. This worked well, ignition on, but also same problem, I can not learn the key. Partnumbers I will post on monday.
Thanks for your interest.
Greetings MR...
CN cheng (27th November, 2017)
Tango recognized your smartbox dump:
key pos: 1 banned
key pos: 2 banned
key pos: 3 good
key pos: 4 good
key pos: 5 good
key pos: 6 empty
key pos: 7 empty
key pos: 8 empty
Have you tried to load any similar dumps in your vvdi2?
Besides that vvdi2 does not read the key.
You could have someone make and mail you the key.
Leaving all other modules as is.
Higlander 2014 after a small accident and a bad battery does not see the keys. On the panel the text "key is not recognized" and does not respond to the buttons. The Steringlock is open and does not close. In the diagnosis, S CODE CHECK have NG.
Please help me or kick me in the right direction.
Sorry for bad english.
Here the partnumber of my 2017 RAV4:
ID-Code-Box: 89784-42051
Smartbox: 89990-42091
Problem is solved, key is learned.
Greetings MR...
Yes, I found out my self how to reset the id code box with only changing 15 Bytes. May I post how? Or doesīnt want this all the filepassworder? :-)
Greetings MR...
ucokseparoh (28th November, 2017), urcarpc (10th April, 2023)
ekas (24th January, 2019)
Yes, of course. For me itīs no problem to share how to reset the id-box with 93c56. See attachment. I think, its important not to delete to much in dump, because this car has elv. How I resetted the box is enought to teach in a used key, of course the smartbox has to be reset also. I dont know, whether this works for all cars with id-box 93c56, but for my RAV4 2017 it was the right way.
Greetings MR...
the dump is only resetted partially..but that doesnt matter since you managed to start the car
ucokseparoh (5th December, 2017)
hello mates i have a complicated situation ,,, its lexus lx570 , have all key lost situation , and the car was with others whom tried programming but with no success
now i have the 3 files of steering lock and ID-BOX and smart unit i need to reset
also the complicated part that the file in smart unit was replaced with other file so i post tow smart files wich i dont know what is the original file for the part
details about the ecu's:
steering lock with 93c46
and ID-BOX with 93c46
smart key unit and two files for 93c86 part number 89990-60180
please i need help thanks alot
kyawkyaw (14th December, 2017)
