***Toyota Smart Lost Key Solution - No Id code needed***
Page 1 of 125 1234561151101 ... LastLast
Results 1 to 15 of 1871
    DK Veteran rashid01's Avatar
    UAE
    can work land cruser ?
  2. The Following 5 Users Say Thank You to rashid01 For This Useful Post:
    elkcengiz60 (31st March, 2017), sahadsky (18th January, 2018), tahaali (5th November, 2023), troper (9th January, 2016), VVDI (2nd October, 2019)
  3. #2
    UAE
    after 2 3 day will send u file becose land cruser dump 2013 frist need replce body control
  4. The Following User Says Thank You to rashid01 For This Useful Post:
  5. #3
    UAE
    Default add key to dump
    hi car have one key smart system is not working just tuch key with start bottn car stat I make i d code and smar virgin now problem is start boton is out off order cant exeet key when I try to add ke y via intlgent tester so lz add key to dump
  6. The Following 12 Users Say Thank You to rashid01 For This Useful Post:
    amaradiarra (19th April, 2019), autokihen (28th December, 2018), emmanuelmella (29th December, 2019), kyawkyaw (13th September, 2015), lanefi (9th May, 2020), Lex8 (15th June, 2021), lylezim (13th November, 2016), MARIKO (2nd March, 2021), OSAMA ALNAHARI (18th December, 2018), syaripudin156 (4th May, 2017), UliZam (5th December, 2016), zeen1974 (30th October, 2019)
  7. #4
    UAE
    Default key data
    tuch swich and old key is out of order
  8. The Following 2 Users Say Thank You to rashid01 For This Useful Post:
    kyawkyaw (13th September, 2015), sahadsky (18th January, 2018)
  9. #5
    UAE
    i no need old key cancel old key and add new that i give key data
  10. The Following User Says Thank You to rashid01 For This Useful Post:
  11. #6
    UAE
    do u have set of id code and smart box dump plz add that key
  12. The Following User Says Thank You to rashid01 For This Useful Post:
  13. #7
    brand new key
    PG1 = 98
    PG2 = F2
    PG3 =3F823A1D
    PG8 = 983738AE44
    Tnx
  14. The Following 10 Users Say Thank You to eepromRipper For This Useful Post:
    abdou elec (30th January, 2016), canisha (9th January, 2022), immokill (21st June, 2021), kyawkyaw (13th September, 2015), nawwaf56 (21st April, 2021), neimy (27th December, 2015), sahadsky (18th January, 2018), syaripudin156 (4th May, 2017), vomit (27th November, 2018), zeen1974 (30th October, 2019)
  15. #8
    UAE
    tomarrow will go to car chack and report
  16. The Following 2 Users Say Thank You to rashid01 For This Useful Post:
    DS98 (9th June, 2021), sahadsky (18th January, 2018)
  17. #9
    UAE
    i need smart systom working esl i will add shake hand data
  18. The Following 4 Users Say Thank You to rashid01 For This Useful Post:
    DS98 (9th June, 2021), Kelvin otas (21st February, 2024), odorepairer (21st January, 2017), sahadsky (18th January, 2018)
  19. #10
    Quote Originally Posted by gwee View Post
    For you, i believed i had started few cars for you all these days.
    When you needed help, skype and email very fast, job finished --- no news, not even the Chrysler dump you promised.
    You won't get any more help from me or any of my friends!!
    GWEE, i think you should have maile me before concluding. i have not even tested the dump, that is the same dump i sent to you again with a new key because i cant find the other key after i resume from sickness.
  20. The Following 2 Users Say Thank You to eepromRipper For This Useful Post:
  21. #11
    Thanks but all the new keys i have is 98, but they have same board 271451-0140 which the original key should have. tnx all the same
  22. The Following User Says Thank You to eepromRipper For This Useful Post:
  23. #12
    UAE
    thankssssss gwee smart systm now work but car not start that is no problem i will repir that thanks too
  24. The Following User Says Thank You to rashid01 For This Useful Post:
  25. #13
    UAE
    now i can start car no problem problem was solve smart systom working
  26. The Following User Says Thank You to rashid01 For This Useful Post:
  27. #14
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by rashid01 View Post
    5 minutes with either of them depending on the years.
  28. The Following 6 Users Say Thank You to super jumbe For This Useful Post:
    cordero (9th April, 2021), igorr (11th February, 2017), line44 (17th May, 2017), Paranoiak (10th October, 2017), pongsky (30th January, 2018), shadab (19th February, 2016)
  29. #15
    UAE
    [QUOTE=super jumbe;2251820]5 some time car start botton smart box got problem to exepet key to tuch start botton then i put dump to new smartbox and replace start botton car expet key after done register key i take out smartbox 93c86 dump to old smart box and old start botton every thing fine
